Old 02-19-2023, 09:32 PM   #1
my4dv8
Default 32 cabriolet door hinges
Our cabriolet has had hurt and welded door hinges , welded repair while on the car , not pretty. Question can 32 roadster hinges be used as a replacement? I see the door hinge appears riveted to the door ,while the A pillar hinge is screwed on .
my4dv8 is offline   Reply With Quote
Old 02-20-2023, 08:05 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 32 cabriolet door hinges
Probably the 5W coupe ones made by UP.Door thickness thicker than roadster.
deuce lover is online now   Reply With Quote
Old 02-20-2023, 09:56 AM   #3
DavidG
DavidG's Avatar
Given the much higher location of the upper hinge on a standard/sport coupe door, that hinge is likely too long compared to the upper hinges on cabriolets and roadsters. Brookville roadster hinges might be the best bet.
Old 02-20-2023, 11:42 AM   #4
Karl Wescott
Karl Wescott's Avatar
1932 Roadster are definitely shorter up and down.
1932 5window/Sedan appear to be the same hinge though I would suspect the mounting holes for the upper hinge (at least) are different, as it is reversed and in a different location.
If you prefer a USA part to United Pacific's Taiwan set, we do make them in investment cast steel, not drilled for mounting, and of course a higher price than UP.
Karl Wescott is offline   Reply With Quote
Old 03-29-2023, 01:00 PM   #5
my4dv8
According to speedway motors the UP 5W hinges are 3 1/8 long . The cab hinges are 4” . would the Wescott or UP ones be easy enough to modify ? ok Wescotts say 4 1/8” and 3 3/8 undrilled .looking more hopefull. While the bottom cabriolet hinge is 4 1/8” the top one measure 3 7/16”
Old 04-03-2023, 12:47 AM   #6
my4dv8
I cant seem to find a direct online order system for Wescott . I have sent a PM to Karl asking how to order a few days ago, as yet no reply. I did send an email to info@wescott as this was all I could find.
Old 04-03-2023, 01:58 AM   #7
Randy in ca
Randy in ca's Avatar
Originally Posted by my4dv8 View Post
i cant seem to find a direct online order system for wescott . I have sent a pm to karl asking how to order a few days ago, as yet no reply. I did send an email to info@wescott as this was all i could find.
ORDERS ... 1-800-523-6279
Was going to suggest you just use the phone order number, but just noticed your location, so guess you'll have to be patient or pay the price for calling.
Randy in ca is offline   Reply With Quote
Old 04-03-2023, 02:43 AM   #8
deuce lover
Click on his user ID (Karl Wescott) in post #4 and a window drops down to give you a choice to send an email or private message.
View Public Profile
Send a private message to Karl Wescott
Send email to Karl Wescott
Visit Karl Wescott's homepage!
Find More Posts by Karl Wescott
Add Karl Wescott to Your Contacts
Old 04-03-2023, 09:59 AM   #9
TJ
TJ's Avatar
Karl was at the Portland Swap meet last week so he was gone from the shop and maybe his computer.
Old 04-03-2023, 10:48 AM   #10
Karl Wescott
email had been received, now replied. parts are in stock.
Old 04-03-2023, 02:14 PM   #11
my4dv8
Thanks for the reply Karl. Parts ordered . Brilliant.
