32 cabriolet door hinges Our cabriolet has had hurt and welded door hinges , welded repair while on the car , not pretty. Question can 32 roadster hinges be used as a replacement? I see the door hinge appears riveted to the door ,while the A pillar hinge is screwed on .
Re: 32 cabriolet door hinges 1 Attachment(s)
Probably the 5W coupe ones made by UP.Door thickness thicker than roadster.
Re: 32 cabriolet door hinges 3 Attachment(s)
Given the much higher location of the upper hinge on a standard/sport coupe door, that hinge is likely too long compared to the upper hinges on cabriolets and roadsters. Brookville roadster hinges might be the best bet.
Re: 32 cabriolet door hinges 1932 Roadster are definitely shorter up and down.
1932 5window/Sedan appear to be the same hinge though I would suspect the mounting holes for the upper hinge (at least) are different, as it is reversed and in a different location. If you prefer a USA part to United Pacific's Taiwan set, we do make them in investment cast steel, not drilled for mounting, and of course a higher price than UP. |
Re: 32 cabriolet door hinges According to speedway motors the UP 5W hinges are 3 1/8 long . The cab hinges are 4” . would the Wescott or UP ones be easy enough to modify ? ok Wescotts say 4 1/8” and 3 3/8 undrilled .looking more hopefull. While the bottom cabriolet hinge is 4 1/8” the top one measure 3 7/16”
Re: 32 cabriolet door hinges I cant seem to find a direct online order system for Wescott . I have sent a PM to Karl asking how to order a few days ago, as yet no reply. I did send an email to info@wescott as this was all I could find.
Re: 32 cabriolet door hinges Quote:
ORDERS ... 1-800-523-6279 - Was going to suggest you just use the phone order number, but just noticed your location, so guess you'll have to be patient or pay the price for calling. |
Re: 32 cabriolet door hinges Click on his user ID (Karl Wescott) in post #4 and a window drops down to give you a choice to send an email or private message.
View Public Profile Send a private message to Karl Wescott Send email to Karl Wescott Visit Karl Wescott's homepage! Find More Posts by Karl Wescott Add Karl Wescott to Your Contacts |
Re: 32 cabriolet door hinges email had been received, now replied. parts are in stock.
Re: 32 cabriolet door hinges Thanks for the reply Karl. Parts ordered . Brilliant.
