Old 09-10-2022, 07:50 PM   #1
19Fordy
19Fordy's Avatar
Default How Do You Tighten 8BA Crank Pulley Bolt
I want to check the torque of the bolt that secures the crank pulley to the crankshaft. The engine is in my 40 Ford.
What is the best method used to prevent the crank from rotating when I tighten the bolt? Bolt tightens by turning it clockwise when standing in front of the car? The torque is 45-55 foot pounds.
Would it be ok to put the transmission "in gear" with emergency brake "on"?
Thanks, JIM
Old 09-10-2022, 08:20 PM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: How Do You Tighten 8BA Crank Pulley Bolt
That's all I ever do.
1948F-1Pickup is offline   Reply With Quote
Old 09-11-2022, 12:54 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Thanks, JIM
Hey Jim.....You've been piddlin' with these old used cars long enough now that you knew that was a good answer. I'd choose 3rd GEAR rather than 1st or 2nd! This affords LESS mechanical advantage for turning the transmission INPUT shaft.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 09-11-2022, 10:46 AM   #4
19Fordy
19Fordy's Avatar
Thank you V8 and 1948F. for the very helpful replies.
Old 09-12-2022, 12:48 PM   #5
theHIGHLANDER
I set the impact on low and call it a day. Been doing that for over 40yrs, no worries yet...
theHIGHLANDER is offline   Reply With Quote
Old 09-12-2022, 01:06 PM   #6
19Fordy
19Fordy's Avatar
I did it the correct way and used a torque wrench.
Besides, you can't use an impact wrench when the engine, radiator, fan and fan pulley set up are in the car. Not enough room.
If possible, let us know how much torque is applied when the setting on your impact wrench is set at "LOW".
Old 09-12-2022, 05:54 PM   #7
ford38v8
ford38v8's Avatar
Cheater bar and a BFH is all you need.
Alan
ford38v8 is online now   Reply With Quote
Old 09-12-2022, 06:24 PM   #8
19Fordy
19Fordy's Avatar
I am truly surprised by the "amateur" approach some have suggested.
Kind of like saying" Cross threading a bolt is ok as long as it holds."
Old 09-12-2022, 07:02 PM   #9
Kube
Kube's Avatar
I'm not at all surprised.
Old 09-12-2022, 07:45 PM   #10
1948F-1Pickup
Nor am I. I’m
Old 09-12-2022, 08:11 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Jim....Have you never heard this end-all phrase that I grew-up with?
"A good cross-thread is far superior to a self-locking nut!"
Coop
T5 W/TORQUE TUBE
Old 09-13-2022, 12:25 AM   #12
ford38v8
ford38v8's Avatar
Ask a stupid question, get a stupid answer. My Momma taught me that.
Alan
