Old 02-04-2022, 12:18 PM   #1
34 fordor owner
34 fordor owner's Avatar
Default Spring Time Work
Well, spring time is coming real soon. Starts warming up here in NC in mid March. I still have yet to get my 34 running. So my plan is to start from the beginning, send the distributor off to a known rebuilder, new condenser, new wires, and figure out how to check timing.
Any suggestions on where to send my distributor to get rebuilt would be great! Previously I sent it off to the guys over at C&G Ford in California. It is the dome style. Also any pointers on timing on a flathead like this would be great as well.
Thank you all!!
34 fordor owner is offline   Reply With Quote
Old 02-04-2022, 12:59 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Spring Time Work
Thank you all!!
That is a "no-brainer"! Send it to "Charlie ny", one of our better-known, long-time members here on the 'Barn. He will even run your distributor on his test engine when he's done making it better than new. DD
Charlie's Cell#: 716-440-8952
Or, you can PM Charlie directly by clicking the link BELOW!
https://www.fordbarn.com/forum/priva...o=newpm&u=1147
Click Links Below __
T5 W/TORQUE TUBE
Old 02-04-2022, 01:32 PM   #3
marko39
The timing will be set when running on a distributor machine.
marko39 is offline   Reply With Quote
Old 02-04-2022, 01:38 PM   #4
Ford Freak
Charlie NY ran my distributor on his test engine after he rebuilt it & set the timing.
Bolted it on my engine 4yrs. ago , and haven't touched it since.
You can't go wrong with Charlie! - Bernie
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 02-04-2022, 09:19 PM   #5
1942deluxe
1942deluxe's Avatar
I had Charlie rebuild my distributor on my 48 business coupe. Fired it up about a week back and thought this thing never ran so good. Should have done it years ago!
Old 02-05-2022, 09:23 AM   #6
RKS.PA
RKS.PA's Avatar
I know your post is about your distributor, but once that is done, if you're moving on to the carburetor, you might also talk to Charlie about that, too!!
As noted here many, many times, he is a gem!!!
RKS.PA is offline   Reply With Quote
Old 02-05-2022, 09:27 AM   #7
corvette8n
corvette8n's Avatar
Charlie rebuilt my carb, and I had him do two distributors, one helmet style and one crab for a spare motor, he does a great job.
Old 02-05-2022, 05:13 PM   #8
51504bat
51504bat's Avatar
Michael at 3rd Gen does them as well. IIRC
Old 02-05-2022, 07:17 PM   #9
34 fordor owner
Thank you all for the suggestions! I will be getting in contact with Charlie real soon for him to rebuild my distributor and possibly my carb.
Again thank you all!
Old 02-12-2022, 04:16 PM   #10
34 fordor owner
Another question, right now I have Autolite 386 plugs in my flat head. I’m fairly new to the flathead scene so I’m not completely sure if these are good plugs for a 34 flathead engine. From what I’ve seen a lot of plugs are better than using Champion plugs. Any suggestions?
Old 02-12-2022, 05:37 PM   #11
Bob NH
Bob NH's Avatar
3RD. Gen in Tenn. is much closer to you so shipping should be less plus the workmanship is way beyond excellent !
Bob NH is offline   Reply With Quote
