Old 03-05-2022, 07:23 AM   #1
36coupe
36coupe's Avatar
Default 36 EB on a 37 Transmission
On DD’s suggestion I fabricated a bracket for my 36 emergency brake on the 37 transmission. Using the 37 and later transmission mount and transmission does not have a provision for the 36 mount. I have to finish and paint the mount but I’m happy with the location and it feels nice and solid. It comes up through the floor in the stock location. I’ll post a finished picture later.
You can see my temporary none adjustable clutch rod that until I fabricated until I find a 39 clutch arm in the background. I have 3 main items and lots of small ones left on the list, patch pin holes in the gas tank, run a gas line, oil lines for the oil filter and install my nos radiator ( still a lot of figuring to be done on that one). Then I will have a running moving chassis and I can get the body in the shop.
36coupe is offline   Reply With Quote
Old 03-05-2022, 07:10 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 36 EB on a 37 Transmission
That'll work. Nice job.
Old 03-05-2022, 09:02 PM   #3
36coupe
36coupe's Avatar
Thanks LC.
Here is a few more pictures.
I’m happy.
File Type: jpg 5DC83286-EC93-4BB8-8A78-22753AC9070D.jpg (62.3 KB, 37 views)
File Type: jpg 89526812-A5DE-4B21-A339-0CAFE30E50DE.jpg (50.2 KB, 38 views)
File Type: jpg 685FDA3C-9B9F-4E00-907E-0A5336D1D252.jpg (54.3 KB, 46 views)
Old 03-07-2022, 05:15 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
I haven't been following your previous threads on this same subject, but I'm wondering why you didn't just use a '35-'36 rear transmission mount & bearing retainer assembly that already has a provision for mounting the '35-'36 emergency brake lever and mounting bracket? Just curious. Would have made your conversion a lot easier.
John
Old 03-07-2022, 09:56 PM   #5
39fordtruck
Okay ��
39fordtruck is offline   Reply With Quote
Old 03-07-2022, 11:04 PM   #6
36coupe
36coupe's Avatar
Good question
A couple of reasons I didn’t have a usable 36 transmission mount. I did have a 37 frame mounts plus the transmission mounts. Figured the 37 was an up grade over the 36. I have time and less money. That always seems to be the way when you work no time, not working lots of time. A 55$ bearing retainer is over a 100$ cad by the time it gets here. I could have gone with a under the dash lever but this was more fun. I line my own brake linings because I can. I have a nice welder so any excuse to use it is go by good.
I’m real happy with the results because when a ford guru looks in the window he will see a original 36 eb. Lots of time and no money spent doing what gives me satisfaction. Doesn’t take much to make me happy lol.
Old 03-08-2022, 02:05 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
Good question
Ya know, you've got a pretty decent attitude about STUFF! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-08-2022, 08:17 PM   #8
JM 35 Sedan
Good question
Lindsey, if it works and you're happy, that's all that really matters.
John
Old 03-09-2022, 08:55 AM   #9
FlatTopFreddie
we made a similar bracket for our Model A's with F150's ... good idea and good job
FlatTopFreddie is offline   Reply With Quote
