Old 01-03-2022, 10:16 PM   #1
Bruce/CT
Default 1936 Radiator Bolting Position
Hi Barners,
I remember these two questions being discussed here some time ago but cannot remember the answer. I have tried to search here but with no luck.
#1. There are 2 bolt holes on the right and left sides in the bottom front frame cross member. A passenger car is bolted thru either the front two or the back two.
Which ones does a passenger car used?
#2. How does the radiator mounting bolts and springs attach? Above or below the frame?
I don't want to do this wrong and have to redo it.
Thanks in advance, Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford
Bruce/CT is offline   Reply With Quote
Old 01-03-2022, 11:11 PM   #2
TagMan
Default Re: 1936 Radiator Bolting Position
Bolt holes closest to the engine are for cars. Ones farthest from engine are for trucks.
TagMan is offline   Reply With Quote
