The Ford Barn
-   -   1936 Radiator Bolting Position (https://www.fordbarn.com/forum/showthread.php?t=308457)
Bruce/CT 01-03-2022 10:16 PM
Hi Barners,
I remember these two questions being discussed here some time ago but cannot remember the answer. I have tried to search here but with no luck.
#1. There are 2 bolt holes on the right and left sides in the bottom front frame cross member. A passenger car is bolted thru either the front two or the back two.
Which ones does a passenger car used?
#2. How does the radiator mounting bolts and springs attach? Above or below the frame?
I don't want to do this wrong and have to redo it.
Thanks in advance, Bruce/CT
TagMan 01-03-2022 11:11 PM
Re: 1936 Radiator Bolting Position
Bolt holes closest to the engine are for cars. Ones farthest from engine are for trucks.
