Old 07-30-2021, 11:20 AM   #1
Russell Reay
Russell Reay's Avatar
Default Steering box washers
In disassembling my steering box I took photos of every part as I went--good thing! The end plate did not have an anti-leak tube, and right behind the light switch bracket were a concave steel washer and a thick cork washer / spacer.
Reassembling the box, and using an end plate with tube, Les' sketch does not show the washer or cork piece. What are their function? I would attach a photo if the website would allow.
Russell Reay is offline   Reply With Quote
Old 07-30-2021, 11:32 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Steering box washers
I think those are eliminated if you're using the plate w/tube. I could be wrong. Bratton's has a diagram here and I think the parts you're talking about are numbers 38 and 6.
Old 07-30-2021, 11:45 AM   #3
Russell Reay
I think you are right. I just checked, and the hole in the two parts isn't big enough to accommodate the horn rod.
Old 07-30-2021, 12:35 PM   #4
Ruth
You are referring to the original seal for the bottom of the steering box. They are not used with the new type of end plate with the tube.
https://www.snydersantiqueauto.com/S...rd?word=a-3527
Ruth
