Old 11-08-2021, 09:24 PM   #1
elwood
elwood's Avatar
Default Merc crank clean out plugs
Hey guys, so I told the guy I needed a tap and a plug for a 5/8 hole, this is what I got,
Is the correct tap and plug size ?
Thanks ..
elwood is offline   Reply With Quote
Old 11-08-2021, 09:52 PM   #2
tomcarman
tomcarman's Avatar
Default Re: Merc crank clean out plugs
Not by my standards. 3/8" and 5/8" are 1/4" apart in size. Perhaps someone misunderstand.
tomcarman is offline   Reply With Quote
Old 11-08-2021, 10:04 PM   #3
Zeke3
Zeke3's Avatar
The nominal OD of a 3/8" pipe is 0.675" and the tap drill size for 3/8" NPT threads is 37/64", so the 3/8" pipe plugs might work for your application.
Zeke3 is offline   Reply With Quote
Old 11-08-2021, 10:23 PM   #4
GB SISSON
GB SISSON's Avatar
I pretty much get all this, but without going down to the shop, did the 4" crank use some kind of press in plugs originally? Won't these threaded plugs change the balance? I have a recently turned merc crank and it came back witout plugs and IIRC it's up to me to clean out the chips. I think threaded plugs would be more secure. Keep up the discussion on the drill/tap/plug combination and I will assume an allen head type pipe plug. Thanks!
Old 11-08-2021, 11:17 PM   #5
flatjack9
flatjack9's Avatar
Nothing wrong with the proper press in plug. They've lasted for at least 70 years in these engines.
Old 11-08-2021, 11:52 PM   #6
Brian
Brian's Avatar
yes! you can tap out the holes in the crank 3/8 NPT and screw in the appropriate 3/8 plugs. Obviously, clean out all swarf etc generated by this procedure....
Old 11-09-2021, 12:54 AM   #7
transbytip
When I did my Merc.crank I ordered the plugs from Summit nice alum.plugs.Cliff.
transbytip is offline   Reply With Quote
Old 11-09-2021, 01:46 AM   #8
vincent
I made them from soft aluminum on my lathe.
vincent is offline   Reply With Quote
Old 11-09-2021, 08:06 AM   #9
Frank Miller
Frank Miller's Avatar
I got brass ones on amazon. Came in a set of 5. I used the 5th one for the hole behind the cam gear. For some reason or other the chinese cast iron ones from the hardware store did not fit but the brass ones went in nicely. One has slightly better tolerances I guess or it is the tap I had. Either way the cast iron ones are a hare bigger.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 11-09-2021, 03:22 PM   #10
Desoto291Hemi
Yes,,,,3/8 pipe thread is the correct size for Merc clean out hole .
Just take your time with the tap,,,,,these cranks are fairly hard .
Tap a little and clean out shavings some,,,,,it’s not too hard,,,just make sure to tap deep enough for the plug to screw in pretty flush .
I like to use Tap Magic for lube,,,it taps better .
Or use stock type cup plugs,,,they work fine as well .
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 11-09-2021, 03:53 PM   #11
GB SISSON
GB SISSON's Avatar
And I will assume some loctite whichever route I choose?
Old 11-09-2021, 04:31 PM   #12
bobH
Just for info.... the 'cup-type' plugs that I have, came from Dorman. Available at my local parts store. Seems to me, they look same as original factory plugs. (for me, press in, no loctite. But, I see no reason that loctite would hurt.)
bobH is offline   Reply With Quote
Old 11-09-2021, 04:45 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
Considering that Ford used the drive in plugs for millions of miles with no issues (known to me)
I chose to use the Dorman 555-010 plugs. No Loc-tite, drive in, 3-4 stake marks.
