The Ford Barn
-   -   Merc crank clean out plugs (https://www.fordbarn.com/forum/showthread.php?t=306251)
elwood 11-08-2021 09:24 PM
1 Attachment(s)
Hey guys, so I told the guy I needed a tap and a plug for a 5/8 hole, this is what I got,
Is the correct tap and plug size ?
Thanks ..
tomcarman 11-08-2021 09:52 PM
Re: Merc crank clean out plugs
Not by my standards. 3/8" and 5/8" are 1/4" apart in size. Perhaps someone misunderstand.
Zeke3 11-08-2021 10:04 PM
The nominal OD of a 3/8" pipe is 0.675" and the tap drill size for 3/8" NPT threads is 37/64", so the 3/8" pipe plugs might work for your application.
GB SISSON 11-08-2021 10:23 PM
I pretty much get all this, but without going down to the shop, did the 4" crank use some kind of press in plugs originally? Won't these threaded plugs change the balance? I have a recently turned merc crank and it came back witout plugs and IIRC it's up to me to clean out the chips. I think threaded plugs would be more secure. Keep up the discussion on the drill/tap/plug combination and I will assume an allen head type pipe plug. Thanks!
flatjack9 11-08-2021 11:17 PM
Nothing wrong with the proper press in plug. They've lasted for at least 70 years in these engines.
Brian 11-08-2021 11:52 PM
yes! you can tap out the holes in the crank 3/8 NPT and screw in the appropriate 3/8 plugs. Obviously, clean out all swarf etc generated by this procedure....
transbytip 11-09-2021 12:54 AM
When I did my Merc.crank I ordered the plugs from Summit nice alum.plugs.Cliff.
vincent 11-09-2021 01:46 AM
I made them from soft aluminum on my lathe.
Frank Miller 11-09-2021 08:06 AM
I got brass ones on amazon. Came in a set of 5. I used the 5th one for the hole behind the cam gear. For some reason or other the chinese cast iron ones from the hardware store did not fit but the brass ones went in nicely. One has slightly better tolerances I guess or it is the tap I had. Either way the cast iron ones are a hare bigger.
Desoto291Hemi 11-09-2021 03:22 PM
Yes,,,,3/8 pipe thread is the correct size for Merc clean out hole .
Just take your time with the tap,,,,,these cranks are fairly hard .
Tap a little and clean out shavings some,,,,,it’s not too hard,,,just make sure to tap deep enough for the plug to screw in pretty flush .
I like to use Tap Magic for lube,,,it taps better .
Or use stock type cup plugs,,,they work fine as well .
Tommy
GB SISSON 11-09-2021 03:53 PM
And I will assume some loctite whichever route I choose?
bobH 11-09-2021 04:31 PM
Just for info.... the 'cup-type' plugs that I have, came from Dorman. Available at my local parts store. Seems to me, they look same as original factory plugs. (for me, press in, no loctite. But, I see no reason that loctite would hurt.)
51 MERC-CT 11-09-2021 04:45 PM
Considering that Ford used the drive in plugs for millions of miles with no issues (known to me)
I chose to use the Dorman 555-010 plugs. No Loc-tite, drive in, 3-4 stake marks.
https://www.fordbarn.com/forum/pictu...ictureid=44210
