Old 12-05-2020, 07:29 PM   #1
mgambuzza
mgambuzza's Avatar
Default Side Mirror Installation Question
I ordered side mirrors so I don't inadvertently crush my fenders while backing blindly into the garage. They did arrive, but before I made mistakes, I wanted to get advice on how to remove the pin in the hinge, and install the new mirror and pin. I've included pictures of the current hinge, and the new mirror for reference. Can't believe with some of these suppliers that they don't include references or installation instructions on parts that they sell.
mgambuzza is offline   Reply With Quote
Old 12-05-2020, 07:55 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Side Mirror Installation Question
https://www.fordbarn.com/forum/showt...ge+pin+removal
Some ideas. Hope yours isn't rusted in too much.
Mike Peters is offline   Reply With Quote
Old 12-05-2020, 08:36 PM   #3
CC-Mo
CC-Mo's Avatar
I installed what looks like the exact mirror you have. Drivers side. I was able to remove the pin after some oil soak/tapping pin from bottom. So, pick the oil of choice & let it sit for awhile & see how tough it's stuck. Hopefully it'll tap right out.
Southern Missouri
'30 Tudor sedan, Original
'33 5-Widow Coupe, Henry Steel, Merc Flathead, 50's Hotrod style.
CC-Mo is offline   Reply With Quote
Old 12-06-2020, 12:09 AM   #4
whirnot
whirnot's Avatar
They make a pin removal tool, but I have always been able to drill them out if stuck too bad. Just have to be carefull
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 12-06-2020, 10:48 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
I find that the door hinge pins wear and become groved as shown in the exaggerated sketch. To date, I have used a rivet gun with a pointed bit to jack hammer the pins out. However, I would much prefer to use a controlled force tool to press the pins out.
To mount a hinge mirror, I replace the hinge pin with a bolt that protrudes about 0.38" above & below the hinge. The bolt head is cutoff, and the head end threaded to match the existing bolt threads. Open the holes in the mirror to suite the bolt. Mount the mirror using the custom bolt and hex nuts on each end. Use blue thread locker. Cover the hex nuts with chrome acorn nut covers.
Bob Bidonde
Old 12-06-2020, 11:29 AM   #6
The Master Cylinder
The Master Cylinder's Avatar
Excellent sketch, Bob. I bet a lot of people fighting with the pin don't even consider the pin hanging up due to wear.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 12-06-2020, 01:49 PM   #7
mgambuzza
mgambuzza's Avatar
Good news - success! I used a punch after soaking the hinge in PB Blaster all night. It came out in one piece with no issue. It was a little bit of a challenge mounting the new (aligning the new bolt with the hinge) but with a little lithium grease it went in. Next will be the drivers side. Thanks for all the suggestions.
Old 12-06-2020, 05:42 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Good going. Just a small tip. I installed a 5" mirror head instead of the standard 4". Gives you a better view of where you have been... You wouldn't think 1" bigger would make much difference but it really helped me when backing up.
Old 12-06-2020, 07:16 PM   #9
KR500
KR500's Avatar
Before attempting a job like this confirm what diameter hinge pin you are dealing with. There are 9/32 pins for the slant windshield and I believe '31 Cabriolet and Victoria. Also there are replacement oversize pins for the 1/4 inch pins. The 5 inch mirrors are supplied with 1/4 bolt pins and are somewhat loose in the doors. I mounted those 5 inch mirrors on a members slant and turned up 9/32 diameter pins tapped at each end to 8-32 thread. Pins were sized exact length of door hinge plus .010. Threaded into hinge pins 8-32 set screw and then placed short 1/4 -20 short studs down into mirror ends and threaded on acorn nuts supplied with mirror.
KR500 is offline   Reply With Quote
Old 12-06-2020, 07:28 PM   #10
rfitzpatrick
Are you able to actually use your passengner-side mirror? If so, and mine is a PicUp, what's that part-numbers?
Thanks
rfitzpatrick is offline   Reply With Quote
Old 12-06-2020, 07:41 PM   #11
Y-Blockhead
I installed the 5" HEADS on the mirror stems that fit my car.
Old 12-06-2020, 09:16 PM   #12
Dougs 28
Dougs 28's Avatar
https://www.fordbarn.com/forum/hamb/attach/jpg.gif
Here is a picture of the tool to get existing hing pin out, it also has different size pins that you will need to push out existing hinge pin. I picked it up at the early Ford store in San Dimas Ca. earlyfordstore.com
File Type: jpeg 7595E24C-8828-4112-B3AC-EE6C742B0461.jpeg (119.7 KB, 32 views)
Dougs 28 is offline   Reply With Quote
Old 12-06-2020, 11:56 PM   #13
PalAl
PalAl's Avatar
I too installed the 5" mirror head, it makes a huge difference for side and rear vision. No one notices the change.
PalAl is offline   Reply With Quote
Old 12-07-2020, 12:45 AM   #14
Bill G
Bill G's Avatar
I've been searching for a 5" convex mirror. I went to a 4" convex and I am pleased that it expands my field of view, but I would like to go bigger. Does anyone have a lead on t 5" convex?
Old 12-07-2020, 12:00 PM   #15
katy
katy's Avatar
I had that problem, the mounting stud on the mirror was too short. I replaced both mirrors w/5" convex that had longer studs, allowing more adjusting room.
https://truckpartsuperstore.ca/produ...SABEgLCZfD_BwE
Old 12-07-2020, 05:54 PM   #16
father-son
Congrats, you are very fortunate it came out that easy. Our 29 Tudor driver side pin removal was a nightmare. Lots of heat, PB and eventual drilling.
father-son is offline   Reply With Quote
Old 12-07-2020, 11:42 PM   #17
PalAl
PalAl's Avatar
Bill, I GOOGLED 5 inch convex mirror and came up with a bunch of leads
I went with this place
https://www.bigrigchromeshop.com/con....html?show=999
Old 12-08-2020, 04:11 PM   #18
Ed in Maine
I just mounted mirrors on my Victoria (9/32 in. pins) and when I got the mirrors, the pins supplied were wrong. I found that I had to carefully drill out the mirror bracket to receive the 9/32 pins. But a further problem was that the 9/32 pins did not fit snugly in my door hinges. I purchased coiled pins that were slightly over sized and filed them down to fit my hinges. I chucked my pins into my drill press and filled them to fit. The advantage of the coiled pins over the solid pins is that they compress slightly to assist in maintaining at good fit into the hinge. The pins were then cut to length and I used a screw and acorn nut to simulate a domed top on the hinge pin. Ed
Old 12-09-2020, 07:59 AM   #19
desotoguy
Y-Blockhead, do you have a source for the amber cowl light lenses, would like to replace my clear lenses as the are used for turn signals and are more easily seen.
desotoguy is offline   Reply With Quote
Old 12-09-2020, 02:42 PM   #20
shew01
shew01's Avatar
I used these. They worked fine.
https://www.brattons.com/30-31amber-cowl-lens.html
