Old 10-15-2020, 04:54 AM   #1
46fatford
46fatford's Avatar
Default 41 ford sedan vent window glass help
I'm in the process of installing new molded vent window seals and new vent window glass. I know how to install the glass, however I noticed that the rubber(?) that the glass sits in is weathered and cracked. Where can I find that part? What is it called? Also any tips on installing the molded vent window rubber?
Thanks
Matt
"..Nothin' outrun my V8 Ford" (Chuck Berry)
S.M.I.B.
46fatford is offline   Reply With Quote
Old 10-15-2020, 07:18 AM   #2
big job
big job's Avatar
Default Re: 41 ford sedan vent window glass help
I think its called 'glass bedding' most have it on line. I have used in the past friction tape
some times two layers. Oddly I just had my drivers glass and vent done glass co. looks
like it was bedded in silicone probably the new deal. but I'm happy and should be for
$150. sam
big job is offline   Reply With Quote
Old 10-15-2020, 08:54 AM   #3
Darrell S
Darrell S's Avatar
I think that what you are looking for is glass setting tape. I got some from Restoration Specialties. It comes in different thicknesses.
I also found that the new vent window rubber isn't quite as thick as the original leaving a gap to the paint on the door. The rubber I used came with new rivits, it is quite a little project.
Darrell S is offline   Reply With Quote
Old 10-16-2020, 12:13 AM   #4
Graeme / New Zealand
Graeme / New Zealand's Avatar
Yes glass setting tape. C&G and the like have it. Set in the frame by bending the stuff around the edges of the glass and trim off the excess with a box cutter.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 10-16-2020, 09:36 AM   #5
corvette8n
corvette8n's Avatar
Replaced the broken vent window on my ‘41, bought the glass setting tape from Bob Drake, I did mine on a hot sunny day came out great.
