Old 10-18-2015, 02:15 PM   #1
exoilfld
Default 47 brake problems
On my 47 pu, I have new drums, shoes, wheel cyls., line, hoses, and master cyl. Adjusted the shoes as tight as I can make them and bled the system 3 times. the first stroke of the pedal goes almost to the floor. The second stroke gives a good hard pedal. The only other adjustment I can think of is the master cyl rod. I left about 1/8 inch or less play before it starts pushing the cyl. Anyone have any ideas?
exoilfld is offline   Reply With Quote
Old 10-18-2015, 03:21 PM   #2
exoilfld
Default Re: 47 brake problems
No, I adjusted the brakes after bleeding just tight enough to have some drag but not so the wheel would not turn.
Old 10-18-2015, 03:25 PM   #3
exoilfld
The brakes on 47 do not have an adjustment at the bottom, just the upper adjustment. I wonder how the MC rod should be adjusted.
Old 10-18-2015, 03:28 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
I would adjust the shoes to the same amount of drag as you did.....BEFORE bleeding. A 1/16" on the pushrod should be sufficient. Make sure pedal and push rod completely retract via spring. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-18-2015, 03:39 PM   #5
V8 Bob
V8 Bob's Avatar
If the pedal positively returns to it's stop (with a return spring), a 1/32"-1/16" push rod gap is all you need. The actual gap, times the pedal ratio, equals the pedal "free play", so you want to keep the gap as small as possible.
It sounds like you may still have some air in the system, if the brakes are all adjusted properly, and, there are no leaks.
Old 10-18-2015, 04:12 PM   #6
Ford Freak
As V8 Bob said - you still have some air in the system .
Believe me , I've been there many times . Keep on bleeding , it will come out .
Ford Freak is offline   Reply With Quote
Old 10-18-2015, 04:17 PM   #7
Lanny
Lanny's Avatar
Did you bench bleed the new Master cyl first, to get the air out of it ?
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 10-18-2015, 04:46 PM   #8
Old Henry
Old Henry's Avatar
Originally Posted by Lanny View Post
Did you bench bleed the new Master cyl first, to get the air out of it ?.
That was my thought too, not air still in the brake lines. If you had that the brakes would not be a "hard pedal" as you said on the second push. They'd always be "spongy".
Having to "pump up" the brakes with two pushes as you describe sounds like a shoe somewhere is still not adjusted up close enough to the drum.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 10-18-2015, 08:10 PM   #9
exoilfld
I guess I will bleed some more. Don't know how to bleed the MC, just at the wheel cyls. I might try adjusting the shoes until they lock the drums and see what difference that makes on the pedal. Sounds like I have about the right adj. on the push rod.
Old 10-18-2015, 08:21 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
I don't think that's a wise way to try to bleed the system. You may end-up not being able to get the shoes to retract to the nominal adjustment spot because of the EXTRA volume (in each wheel cylinder) downstream of the check mechanism. Adjust the shoes precisely (barely rubbing), then bleed! DD
T5 W/TORQUE TUBE
Old 10-18-2015, 08:28 PM   #11
Talkwrench
Talkwrench's Avatar
If a single circuit system no need to bench bleed. also DO NOT push the pedal all the way to the floor when bleeding, put a bit of wood or something behind it. Speed bleeders are your best friend. http://www.speedbleeder.com/
Old 10-18-2015, 11:50 PM   #12
Lanny
Lanny's Avatar
I put a Wagner rebuilt Single Pot master cyl in a '64 Comet a few years
ago, and the instructions said to bench bleed it before installing in vehicle,
was Wagner wrong
Old 10-19-2015, 12:12 AM   #13
Old Henry
Old Henry's Avatar
was Wagner wrong
That is the same instructions that came with the master cylinder I bought from NAPA for my 47.
Here is one bench bleeding procedure: http://s7d9.scene7.com/is/content/Ge...29488pdf?$PDF$
Here are the installation instructions for my 47 MC that includes the bench bleeding procedure: http://s7d9.scene7.com/is/content/Ge...62928pdf?$PDF$
Old 10-19-2015, 07:56 AM   #14
Cecil/WV
Cecil/WV's Avatar
For me, if I already have working brakes and am just replacing the master cyl, I have found that a bench bleed will almost always eliminate any further bleeding.
Cecil/WV is offline   Reply With Quote
Old 10-19-2015, 02:07 PM   #15
exoilfld
I give up! I have adjusted and readjusted the shoes and bled 5 gallon of fluid through the system and I still have to pump the pedal to have brakes. I had no problem with my 41,38, or 40, but this one has beat me.
Old 10-19-2015, 02:38 PM   #16
JSeery
JSeery's Avatar
Any way you have a wheel cylinder(s) leaking, that is a fairly common issue with the newer ones? There is a procedure for installing them to over come this.
Old 10-19-2015, 03:29 PM   #17
George/Maine
George/Maine's Avatar
I always adjust the brakes first when done should have slide drag. Then make sure you have a returns spring on pedal. What I do is crack the bleeder little so to leak out and pump and see good puddle of fluid on ground don't let pedal go to floor and keep mc full, close the blender and do the same to other ones. Test drive
George/Maine is offline   Reply With Quote
Old 10-19-2015, 03:43 PM   #18
V8COOPMAN
V8COOPMAN's Avatar
Soooo.......you're sayin' you just crack the bleeders one at a time, let it squirt out some, and just end-up with four good puddles of fluid on the ground? Don't get no simpler 'n that. DD
T5 W/TORQUE TUBE
Old 10-19-2015, 04:08 PM   #19
exoilfld
Just read a thread from a senior member from 2011, said he was having the same problem. He thought it was defective MS's(had replaced 2 new ones). I messaged him and asked how he resolved the problem. Have not head back yet.
Old 10-19-2015, 06:09 PM   #20
1931 flamingo
1931 flamingo's Avatar
Which wheel are you bleeding first, second, etc?? How much free play in the pedal?? Original style M/C??
Paul in CT
