Old 03-24-2013, 01:16 AM   #1
Onlybackroads
Onlybackroads's Avatar
Default PTO on a Model A?
Hey everyone, curious about the use of a PTO on a Model A, I'd be interested in using one on a doodlebug. Any info and/or experiences with hooking one up and what kind of PTO unit is adaptable would be greatly appreciated! Gotta mow the lawn soon...
Onlybackroads is offline   Reply With Quote
Old 03-24-2013, 01:33 AM   #2
CarlG
CarlG's Avatar
Default Re: PTO on a Model A?
You could put an AA 4-speed transmission with a PTO. Requires a couple extra parts to adapt the transmission to an A, but they were an option from Ford, and might still be available somewhere.
The extra parts needed are:
A-7085-E Rear Bearing Retainer
A-7090-C U-Joint Assembly
AA-7095 U-Joint knuckle retainer.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-24-2013, 02:07 AM   #3
Onlybackroads
Ok, did some more research tonight... With the 3-speed trans hooked up to the 2-speed under drive, there was a 4-bolt PTO made to fit on the bottom of the 2-speed. And it sounds like they are hard to find. I also found out that there's a different site with AA forums and that's probably where I should ask this, but I like this site and I'm already here!
Any other ways of hooking up a pto? I guess I could always put a belt drive around one of my rear wheels....
Old 03-24-2013, 03:52 AM   #4
ctlikon0712
ctlikon0712's Avatar
Yes, there was a PTO for the AA 4 speed transmission that mounted on the pass/right side of the transmission gear box. It was used for some of the AA accessories of the time like some dump beds and tow wenches etc.....
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 03-24-2013, 07:03 AM   #5
Ken B
Ken B's Avatar
I thought there was a PTO for a Model AA on Ebay recently.
Ken B is offline   Reply With Quote
Old 03-24-2013, 07:21 AM   #6
Ken B
Ken B's Avatar
Here is the Ebay item number: 350476962766
Old 03-24-2013, 08:08 AM   #7
Joe K
Joe K's Avatar
I believe the Model AA four speed (Borg Warner Transmission) has the PTO blank on the passenger side as mentioned. Also this blank/connection is an SAE standard: there may be MANY PTO boxes that will fit it.
IIRC there are 6 bolt SAE connections (Like the Model AA) and there are 8 and beyond bolt connections: other than the number of bolts the setup is similar but the larger units are definitely the 6 bolt on steroids. You can search on the internet using search terms 6 bolt SAE PTO and come to MANY brochures and an outline of the standards from different makers. One I picked out was http://www.metaris.com/catalogs/PTO-Catalogue-V3.pdf
Back when I was trying to get an AA truck together for my own use, I found a PTO takeoff at one of the fleamarket/engine shows for $5. It was totally worn out but could have been rebuilt for use.
Joe K
Shudda kept the horse.
Old 03-24-2013, 08:34 AM   #8
George Miller
George Miller's Avatar
I built one once used it to run a bush hog, and plow snow. If you look close you can see the pto under the rear axle. can not find a picture of it when it was finished. Used a Model A truck 4 speed with a pto. It also had a 3 point hitch and live hydraulics.
George Miller is offline   Reply With Quote
Old 03-24-2013, 08:43 AM   #9
George Miller
Here is another picture of it when I was building it.
Old 03-24-2013, 06:54 PM   #10
Onlybackroads
That looks like a fun build George, can't wait to start my build.
The project I'm getting has a 3-speed tranny and a 2-speed underdrive box, so I'm going to need a 4-bolt PTO if I want to run one on that setup. It bolts onto the underside of the underdrive. I'd really rather not hook up a whole new transmission and just use what I have, so if anyone hears of a 4-bolt for sale, let me know!
Old 03-24-2013, 10:18 PM   #11
Bob C
Four bolt PTO's cost big bucks,if you can find one.
Bob
Old 03-24-2013, 11:15 PM   #12
Onlybackroads
So it seems, hopefully I can find one hiding somewhere
Old 03-26-2013, 05:28 AM   #13
George Miller
Here is a picture of the finished tractor.
Old 03-26-2013, 05:45 AM   #14
roccaas
roccaas's Avatar
I don't guess a wide leather belt running around the "tireless" rear wheel and attached to some rotary device qualifies?
I'm waiting to see this on Duck Dynasty, Moonshiners, or Antique Loggers.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 03-26-2013, 07:11 AM   #15
29ModelA
29ModelA's Avatar
Duck Dynasty already did it
https://www.youtube.com/watch?v=HKsO3U-IXvg
1929 Model A Barn find. California car, just a few more parts to find.
Interior, steering box (rebuild), and I am sure much more!
29ModelA is offline   Reply With Quote
Old 03-26-2013, 11:15 AM   #16
Rowdy
I have a couple of PTO's. None correct for the AA 4 spd. I have not deternined what the gears are meant to mesh with. Bolt pattern looks to be correct for the AA, but they have double drive gears. I can dig them out later this week if you think they may mesh with the underdrive secondary transmission. Rod
Rowdy is offline   Reply With Quote
Old 03-26-2013, 04:14 PM   #17
FordMike
I have a 4 bolt pto for the bottom of the dual high box on the shelf somewhere. I can dig it out and snap you a few pics if you'd like to use them as a reference.
FordMike is offline   Reply With Quote
Old 03-26-2013, 04:44 PM   #18
1crosscut
1crosscut's Avatar
I'd like to see pictures of it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-26-2013, 04:49 PM   #19
FordMike
Here are the pics of the 4 bolt pto, along with a diagram for installation with the factory dual high auxiliary drive.
As for rarity, this is the only one I have ever seen and I don't know of anyone else who has one.
I also have a 4 spd trans with a pto on it if you would like some pictures of that too, that also has the factory handles to control it.
Sorry for the huge pics, hopefully this will help.
Old 03-26-2013, 06:09 PM   #20
1crosscut
1crosscut's Avatar
Thanks for the pictures. It's a bummer that the corner of the pto is broken but still having the rest of the ear it can be fixed. I'm just about to pull my dual high apart to replace the seals etc... nice to see what the pto looks like.
