Old 02-13-2020, 05:55 PM   #1
Borninthefifties
Default Loctite for pressure plate finger adjusting nuts
I am wondering how many Model A folks use Loctite to lock down pressure plate finger adjustment nuts instead of staking the nuts and if any of you have had any problems with this method. Also which is the best formula of Loctite to use (number and color)
Borninthefifties is offline   Reply With Quote
Old 02-13-2020, 06:19 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Loctite for pressure plate finger adjusting nuts
I use Loctite on all fasteners. there is one for every application. I would recommend the red that needs heat to undo.
Old 02-13-2020, 08:34 PM   #3
ryanheacox
ryanheacox's Avatar
There is also a green version that will wick into the threads after you get it adjusted right. I think it's the same strength as the red.
Old 02-13-2020, 09:24 PM   #4
Synchro909
Synchro909's Avatar
That's # 290, a favourite of mine. Assemble everything, adjust if necessary, then apply the loctite. Nothing could be easier.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-14-2020, 09:35 AM   #5
Borninthefifties
Has anyone had a bad experience using just thread locker?
Old 02-14-2020, 03:23 PM   #6
Werner
Werner's Avatar
Hey Fiftees born man. I did that with threadlocker varnish. Available in aviation shops.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
