Old 01-26-2011, 08:18 PM   #1
leo
leo's Avatar
Question Get the Red Out (Down) in that Motometer
I have a nice original Motometer with the mercury all the way to the top with no gaps. I've tried tapping the stem on a tire to no avail. Any other ideas about how to get the mercury back where it belongs that work?
leo is offline   Reply With Quote
Old 01-26-2011, 08:22 PM   #2
Jason in TX
Jason in TX's Avatar
Default Re: Get the Red Out (Down) in that Motometer
Tie a string around the motometer so that it hangs top side up. Then spin around above your head like a helicopter. This centrifugal force will push the red down into the base.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 01-26-2011, 08:26 PM   #3
Gary WA
Gary WA's Avatar
Did you try to heat with boiling water then cool water on the stove?www.whidbeymodelaclub.com
Old 01-27-2011, 09:40 AM   #4
Logan
Logan's Avatar
If you go strait from hot to cold, you will crack it.
Cowtown A's
Logan is offline   Reply With Quote
Old 01-27-2011, 10:35 AM   #5
Jason in TX
Another similar tip I read is put it in a sock and spin it around. Same idea as the string.
The concept is exactly the same as when you used to have to shake the old thermometers back down after taking your temperature. Use gravity. Spinning it around on a string just helps you not kill your arm by doing the thermometer flick.
Old 01-27-2011, 12:43 PM   #6
Afordman31
Afordman31's Avatar
Thumbs up Re: Get the Red Out (Down) in that Motometer
Leo
My Dad said to put it in the freezer overnight than tap it on a tire. He said that works.
Afordman31 is offline   Reply With Quote
Old 02-01-2011, 08:34 AM   #7
leo
leo's Avatar
The freezer trick worked very well. Thank you.
