Old 10-26-2019, 04:09 PM   #1
Werner
Werner's Avatar
Default Mechanic lock starter motor if 'pre-ignition'
Hallo,
there is a mechanical tool that prevents to push down the starter motor button if it is forgotten to set the ignition to "late". What's, please, is the name of this tool, so I can search it?
Thank you very much!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-26-2019, 04:43 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Mechanic lock starter motor if 'pre-ignition'
The only such tool I'm aware of is a 'pre-flight- post-flight checklist'.
Old 10-26-2019, 04:56 PM   #3
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
There was a Gizmo advertised at one time that actually used the spark lever to engage the starter. But I've never heard of what you are referring too. But just because I've never seen it doesn't mean anything!
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 10-26-2019, 06:29 PM   #4
rotorwrench
rotorwrench's Avatar
There may have been aftermarket gizmos available. Folks came up with all sorts of inventions to sell to Ford owners.
Old 10-26-2019, 08:46 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
I think that the gizmo that you refer to
was the Fulton up start .
Old 10-26-2019, 08:52 PM   #6
J Franklin
J Franklin's Avatar
It is called up-start. here is a link to it from Bratton's.
https://www.brattons.com/catalogsear...lt/?q=up-start
Old 10-26-2019, 09:24 PM   #7
Blue-Truck-Nut
The Up Start is pretty close, but the device I'm remembering mounted under the hood, and had a bell crank like contraption.
When the spark rod was moved to full retard it would engage the starter.
Not exactly what the OP was looking for, but I think we are getting closer!!
Old 10-26-2019, 09:56 PM   #8
J Franklin
J Franklin's Avatar
I think the up-start also is linked to the spark lever on the column.
Old 10-26-2019, 09:59 PM   #9
Blue-Truck-Nut
The one from brattons appears to be a rod with a knob that runs up the column. Not completely sure.
Old 10-26-2019, 11:23 PM   #10
J Franklin
J Franklin's Avatar
Well this one looks more like it!
https://www.brattons.com/sparky-start-system.html
Old 10-26-2019, 11:26 PM   #11
Blue-Truck-Nut
Bam! You sir are a gentleman and a scholar!
Old 10-27-2019, 06:28 AM   #12
Patrick L.
Patrick L.'s Avatar
Hmm, that contraption is interesting. So those of us that retard our spark at shutdown will now have to put up with the starter spinning all night. [smiley face]
Old 10-27-2019, 07:51 AM   #13
Railcarmover
It was for women,so they don't rip a stocking or scuff a shoe toeing the starter button..
Railcarmover is offline   Reply With Quote
Old 10-27-2019, 08:41 AM   #14
chrs1961815
chrs1961815's Avatar
Check out the Sparky Start Thread.
https://www.fordbarn.com/forum/showthread.php?t=267120
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-27-2019, 03:48 PM   #15
Werner
Werner's Avatar
Hallo,
Patrick has right. But sometimes it happens that the late adjustment is forgotten. -
It is a mechanism that blocks the foot starter button to push, if the ignition lever is on "early".
Werner
Citroen 11 CV, 1947
Old 10-27-2019, 08:54 PM   #16
31 Vicky
Or always retard the spark when returning to idle before shutting off.
31 Vicky is offline   Reply With Quote
Old 10-28-2019, 02:34 AM   #17
Werner
Werner's Avatar
That's all right, and so I do. Almost always.
But it is sometimes forgotten. With my Citroen Traction the retard was forgotten. The startermotor has received such a head stroke that the claw is broken.
Therefore, a "early ignition lock" may be useful, I think.
Werner
Citroen 11 CV, 1947
Old 10-28-2019, 05:47 AM   #18
Patrick L.
Patrick L.'s Avatar
I can't find your last post. It must have been pulled.
