The Ford Barn
-   -   Mechanic lock starter motor if 'pre-ignition' (https://www.fordbarn.com/forum/showthread.php?t=271627)
Werner 10-26-2019 04:09 PM
Hallo,
there is a mechanical tool that prevents to push down the starter motor button if it is forgotten to set the ignition to "late". What's, please, is the name of this tool, so I can search it?
Thank you very much!
Patrick L. 10-26-2019 04:43 PM
Re: Mechanic lock starter motor if 'pre-ignition'
The only such tool I'm aware of is a 'pre-flight- post-flight checklist'.
Blue-Truck-Nut 10-26-2019 04:56 PM
There was a Gizmo advertised at one time that actually used the spark lever to engage the starter. But I've never heard of what you are referring too. But just because I've never seen it doesn't mean anything!
Sent from my E6810 using Tapatalk
rotorwrench 10-26-2019 06:29 PM
There may have been aftermarket gizmos available. Folks came up with all sorts of inventions to sell to Ford owners.
Purdy Swoft 10-26-2019 08:46 PM
I think that the gizmo that you refer to
was the Fulton up start .
J Franklin 10-26-2019 08:52 PM
It is called up-start. here is a link to it from Bratton's.
https://www.brattons.com/catalogsear...lt/?q=up-start
Blue-Truck-Nut 10-26-2019 09:24 PM
The Up Start is pretty close, but the device I'm remembering mounted under the hood, and had a bell crank like contraption.
When the spark rod was moved to full retard it would engage the starter.
Not exactly what the OP was looking for, but I think we are getting closer!!
J Franklin 10-26-2019 09:56 PM
I think the up-start also is linked to the spark lever on the column.
Blue-Truck-Nut 10-26-2019 09:59 PM
The one from brattons appears to be a rod with a knob that runs up the column. Not completely sure.
J Franklin 10-26-2019 11:23 PM
Well this one looks more like it!
https://www.brattons.com/sparky-start-system.html
Blue-Truck-Nut 10-26-2019 11:26 PM
Bam! You sir are a gentleman and a scholar!
Patrick L. 10-27-2019 06:28 AM
Hmm, that contraption is interesting. So those of us that retard our spark at shutdown will now have to put up with the starter spinning all night. [smiley face]
Railcarmover 10-27-2019 07:51 AM
It was for women,so they don't rip a stocking or scuff a shoe toeing the starter button..
chrs1961815 10-27-2019 08:41 AM
Check out the Sparky Start Thread.
https://www.fordbarn.com/forum/showthread.php?t=267120
Werner 10-27-2019 03:48 PM
Hallo,
Patrick has right. But sometimes it happens that the late adjustment is forgotten. -
It is a mechanism that blocks the foot starter button to push, if the ignition lever is on "early".
31 Vicky 10-27-2019 08:54 PM
Or always retard the spark when returning to idle before shutting off.
Werner 10-28-2019 02:34 AM
1 Attachment(s)
That's all right, and so I do. Almost always.
But it is sometimes forgotten. With my Citroen Traction the retard was forgotten. The startermotor has received such a head stroke that the claw is broken.
Therefore, a "early ignition lock" may be useful, I think.
Patrick L. 10-28-2019 05:47 AM
I can't find your last post. It must have been pulled.
