Old 05-04-2019, 08:13 AM   #1
Smooth_One
Smooth_One's Avatar
Default How’s your Shortened pitman arm working?
Just wondering All of you out there that have installed the shortened Pitman arm how much of a difference it makes and how do you like it versus stock?
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 05-04-2019, 08:23 AM   #2
Jeff P. / MN
Jeff P. / MN's Avatar
Default Re: How’s your Shortened pitman arm working?
I installed a new one from Snyder’s on my ‘30 Tudor. Steering is much easier. This is the second one I have done. I always use a new one, never a welded one.
Jeff P./MN
1913 Model T Runabout
1926 Model T Sport Touring
1948 Chrysler New Yorker
Jeff P. / MN is offline   Reply With Quote
Old 05-04-2019, 08:25 AM   #3
CWPASADENA
CWPASADENA's Avatar
I have a shortened pitman arm on my 30 Tudor that I use for touring. In over 16 K miles, I would not change back to original. I have 19 inch wheels and tires.
It steers easier and I would recommend it for those who have the original steering box.
The steering box must be in good condition as well as the other steering components.
DO NOT use a shortened pitman arm with the F100 conversion. It makes the steering too slow and imprecise.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-04-2019, 09:34 AM   #4
woofa.express
woofa.express's Avatar
It's like power steering by comparison. However it does put just a little more slop into my sloppy steering and increases the radius of a turn but I recommend them. gary.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 05-04-2019, 09:48 AM   #5
burner31
burner31's Avatar
I like it, I think you will too.
They are not expensive so throw one on, quick and easy.
Keith
Shawnee OK
'31 SW 160-B
Old 05-04-2019, 09:49 AM   #6
katy
katy's Avatar
I installed a new one from Bratton's, steering is easier, I like it.
Old 05-04-2019, 10:09 AM   #7
daveymc29
daveymc29's Avatar
I have a new one, not welded and it works fine with my rebuilt F100 box. Much better than the 7 tooth I had rebuilt. It still turns lock to lock, so I don't seem to suffer the longer turning radius others speak of. I takes more turns to get there but if moving at all it isd a one finger pull on the steering wheel. Made my own box so I cost just about 200 bucks. I used a 56 Ford pickup unit.
daveymc29 is offline   Reply With Quote
Old 05-04-2019, 10:16 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
I liked it so much in my 190A that I bought one for my 45B also.
Bob Bidonde
Old 05-04-2019, 10:57 AM   #9
JtownJoe
JtownJoe's Avatar
I put a new one about 5+ years ago and it made a difference with no complaints.
JtownJoe is offline   Reply With Quote
Old 05-04-2019, 11:06 AM   #10
Purdy Swoft
Purdy Swoft's Avatar
I use the shortened pitman arms from Wiley Higgins in Cumming Georgia . I am well pleased and use the shortened pitman arm on most of my model A's . When moving , they steer about as easily as power steering .
Old 05-04-2019, 11:06 AM   #11
Jim Brierley
I made one back in 1960 for my widebed, bought one for my tudor with the F-100 box a few years ago and have a AA arm on my speedster. I'm happy with all of them. A shortened arm is even more important if the car has been lowered as everything lines up better.
Old 05-04-2019, 11:19 AM   #12
M2M
M2M's Avatar
Everyone is saying they make the steering easier but is there not a downside?
At 45 to 55mph would you notice the loss in steering precision?
M2M is offline   Reply With Quote
Old 05-04-2019, 11:43 AM   #13
Ruth
I have a stock 2 tooth steering box in my '30 Town Sedan and my steering still goes lock to lock also. I don't seem to suffer the longer turning radius others speak of either??
Old 05-04-2019, 11:50 AM   #14
BillCNC
BillCNC's Avatar
What is the length between the centers on the shortened Pitman Arm's?
Regards
Bill
BillCNC is offline   Reply With Quote
Old 05-04-2019, 11:52 AM   #15
Clem Clement
Clem Clement's Avatar
I bought one of Rainmaker Ron's shortened Pitman arms many years ago. Love it.
Miss Ron!
Old 05-04-2019, 12:09 PM   #16
Purdy Swoft
NO , steering radius won't be felt at road speed . Steering radius can only be noticed at maximum left or right turns .
Old 05-04-2019, 02:14 PM   #17
Smooth_One
Smooth_One's Avatar
I just got one from Bert’s and at some spots it’s twice the thickness of the original one. I have not installed it yet.
Isaiah B.
Old 05-04-2019, 02:15 PM   #18
Smooth_One
Smooth_One's Avatar
I did just pick one up from Bert’s but have not put it on the car yet.
Isaiah B.
Old 05-04-2019, 02:16 PM   #19
Smooth_One
Smooth_One's Avatar
Great question.
Isaiah B.
Old 05-04-2019, 02:55 PM   #20
Purdy Swoft
It has been said that a shortened pitman arm will increase the turning circle . In other words the car would require a larger area to turn around in a circle . This hasn't been a problem for us . Some have had more problems with the 28-29 models . The problem in sush cases has been that the shortened pitman arm couldn't pull the spindle back quite far enough to reach its stop . This in turn increases the turning circle .
