How’s your Shortened pitman arm working? Just wondering All of you out there that have installed the shortened Pitman arm how much of a difference it makes and how do you like it versus stock?
Re: How’s your Shortened pitman arm working? I installed a new one from Snyder’s on my ‘30 Tudor. Steering is much easier. This is the second one I have done. I always use a new one, never a welded one.
Re: How’s your Shortened pitman arm working? I have a shortened pitman arm on my 30 Tudor that I use for touring. In over 16 K miles, I would not change back to original. I have 19 inch wheels and tires.
It steers easier and I would recommend it for those who have the original steering box. The steering box must be in good condition as well as the other steering components. DO NOT use a shortened pitman arm with the F100 conversion. It makes the steering too slow and imprecise. My opinion, Chris W. |
Re: How’s your Shortened pitman arm working? It's like power steering by comparison. However it does put just a little more slop into my sloppy steering and increases the radius of a turn but I recommend them. gary.
Re: How’s your Shortened pitman arm working? I like it, I think you will too.
They are not expensive so throw one on, quick and easy. |
Re: How’s your Shortened pitman arm working? I installed a new one from Bratton's, steering is easier, I like it.
Re: How’s your Shortened pitman arm working? I have a new one, not welded and it works fine with my rebuilt F100 box. Much better than the 7 tooth I had rebuilt. It still turns lock to lock, so I don't seem to suffer the longer turning radius others speak of. I takes more turns to get there but if moving at all it isd a one finger pull on the steering wheel. Made my own box so I cost just about 200 bucks. I used a 56 Ford pickup unit.
Re: How’s your Shortened pitman arm working? I liked it so much in my 190A that I bought one for my 45B also.
Re: How’s your Shortened pitman arm working? I put a new one about 5+ years ago and it made a difference with no complaints.
Re: How’s your Shortened pitman arm working? I use the shortened pitman arms from Wiley Higgins in Cumming Georgia . I am well pleased and use the shortened pitman arm on most of my model A's . When moving , they steer about as easily as power steering .
Re: How’s your Shortened pitman arm working? I made one back in 1960 for my widebed, bought one for my tudor with the F-100 box a few years ago and have a AA arm on my speedster. I'm happy with all of them. A shortened arm is even more important if the car has been lowered as everything lines up better.
Re: How’s your Shortened pitman arm working? Everyone is saying they make the steering easier but is there not a downside?
At 45 to 55mph would you notice the loss in steering precision? |
Re: How’s your Shortened pitman arm working? Quote:
Re: How’s your Shortened pitman arm working? What is the length between the centers on the shortened Pitman Arm's?
Regards Bill |
Re: How’s your Shortened pitman arm working? I bought one of Rainmaker Ron's shortened Pitman arms many years ago. Love it.
Miss Ron! |
Re: How’s your Shortened pitman arm working? It has been said that a shortened pitman arm will increase the turning circle . In other words the car would require a larger area to turn around in a circle . This hasn't been a problem for us . Some have had more problems with the 28-29 models . The problem in sush cases has been that the shortened pitman arm couldn't pull the spindle back quite far enough to reach its stop . This in turn increases the turning circle .
