Old 01-29-2019, 07:55 PM   #1
compyello
Default 38 trunk lock cylinder
I am looking for some help removing the lock cylinder on my 38 trunk handle, there is a key broken off in the cylinder and it is in the horizontal position. Any thoughts?
compyello is offline   Reply With Quote
Old 01-30-2019, 11:19 AM   #2
32phil
Default Re: 38 trunk lock cylinder
I have had some limited success removing broken keys using a fine dental pick with a small hook on the end. Make sure everything is well lubed.... once the key is out you can clean the lube out.
If the handle is still on the car …….
AND it is the correct key you maybe able to turn the cylinder 90 degrees and remove the lock cylinder and then push the key out from the rear of the cylinder.
If you are concerned about damaging stuff it may have to go to the hospital......
...if you want my help.... PM me here on the barn after April 7th
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 01-30-2019, 11:45 AM   #3
40cpe
40cpe's Avatar
Horizontal is the correct position of the key for removal of the cylinder. There is a small hole above the cylinder. Something to fit the hole is inserted to push down a spring loaded retainer pin in the cylinder while pulling on the cylinder. Your problem with the broken key is the lack of some way to pull. If you can remove the handle from the trunk you might position the cylinder where a penetrating fluid will soak it and help free it.
Old 01-30-2019, 05:19 PM   #4
compyello
The handle is off of the car, there is nothing inside the small hole (spring loaded or otherwise). I have tried removing the key with no luck. I better take another look.
Old 01-30-2019, 06:03 PM   #5
40cpe
40cpe's Avatar
The spring loaded retainer is at the front of the cylinder. If it is stuck it might be hard to feel.
Old 01-30-2019, 08:18 PM   #6
40cpe
40cpe's Avatar
Pic of cylinder with locking pin
Old 01-30-2019, 08:25 PM   #7
compyello
That might help
Old 01-30-2019, 09:09 PM   #8
compyello
The angle I am getting on the button is not working from the outside so I have been trying on the inside. More attempts tomorrow
Old 02-01-2019, 10:19 AM   #9
JIM, WI
If your key is horizontal, the teeth of the key must be to the right for the spring pin to be depressed. A paper clip works good. Or, if you can turn the key so the teeth are to the top, you may be able to pull the key out with something like a dental pick.
Good luck.
JIM, WI is offline   Reply With Quote
Old 02-03-2019, 10:02 AM   #10
compyello
thank you to all
