Old 01-12-2019, 07:03 PM   #1
philipswanson
Default In Line Fuel Filter Near Gas Tank
I am thinking about installing an in line fuel filter back by the gas tank. Anybody done this? What did you use? I have a totally stock 1940 wagon.
philipswanson is offline   Reply With Quote
Old 01-12-2019, 07:18 PM   #2
40 Deluxe
Default Re: In Line Fuel Filter Near Gas Tank
I just cut the line and added a clear glass filter above the rear axle area. I had a problem with fine rust clogging things up. With that rear filter, the car would quit after 10-15 miles. I'd get towed home and take the filter apart and clean it. I soon found that once the engine ran out of fuel and quit, if I waited a few minutes, the rust flakes would drop off the filter screen and I could go another 10-15 miles. I then replaced the tank. Been running fine ever since. The filter is still there and has not clogged.
Old 01-12-2019, 07:24 PM   #3
ford38v8
ford38v8's Avatar
Use a replaceable clear plastic filter. They come with the connecting hoses and spring clamps, do not use the garbage spring clamps, buy the worm gear clamps. Choose an accessible spot near the tank.
Alan
Old 01-12-2019, 07:25 PM   #4
36rgtop
36rgtop's Avatar
Why do you want to put it in the back?
36rgtop is offline   Reply With Quote
Old 01-12-2019, 07:25 PM   #5
50fordcoupeman
50fordcoupeman's Avatar
I also have a filter near the tank. I have the filter, a shut off valve and an electric pump and then another filter next to carb. I use NAPA pn 3033 filters.
50fordcoupeman is offline   Reply With Quote
Old 01-13-2019, 02:12 PM   #6
philipswanson
I don't want to cut open the front fuel line and risk a fire. Much safer back by the tank.
Old 01-13-2019, 02:34 PM   #7
36rgtop
36rgtop's Avatar
Ya! Gasoline is less flammable in the back
Old 01-13-2019, 04:25 PM   #8
philipswanson
Yea, less things to ignite it in the back like heat and spark. I want to also keep it original under the hood.
Old 01-14-2019, 10:55 AM   #9
V8 Bob
V8 Bob's Avatar
Clear plastic or glass filters are not the best choice, because of durability, regardless of location. Much better are inexpensive common all-metal, or more costly aluminum with SS cleanable filter elements.
Old 01-14-2019, 11:50 AM   #10
19Fordy
19Fordy's Avatar
V8 Bob makes a good point. But, I have had good luck with this set up. I like the visibility.
For the photo, I removed the sheet metal shield that protects the filter. Second photo shows fuel shut off petcock in between tank and electric fuel pump.
Old 01-14-2019, 12:30 PM   #11
flatheadmurre
flatheadmurre's Avatar
There was a nice little plastic filter used in motorcycle tanks that fitted perfectly in the inlet fitting from the tank keeping rust flakes and stuff from entering the lines.
Sadly the place i got them from stopped selling them and i haven´t found a new supplier.
With a screen in the tank and the Fram paper filter in the glass bowl fuel deliery was usually working great.
