Old 12-05-2017, 08:34 PM   #1
TRP
Default Champion C-16 C VS Champion 3x?
Hello Gang,
My car is currently running Champion C-16 C plugs. I pulled them out and they look a little worse for wear. The center electrode is noticeably worn out near the ground electrode. I picked up some Champion 3X's as recommended here.
I am running a C head (with the unique water pump) on an otherwise stock motor. Should I have any concern with such a swap?
I posed this question on the original 'which plug do you run' thread. It looked like it was going to get lost in a hurry. I moved it here.
Thank you for your time,
Ted
TRP is offline   Reply With Quote
Old 12-05-2017, 10:24 PM   #2
ursus
Default Re: Champion C-16 C VS Champion 3x?
With a C Head you are still running a low compression engine (at 4.6/1). The C16C plugs were a replacement for the C-4 plugs made for the C-head which were a replacement for the 3X plugs. You will be fine with the 3X plugs.
ursus is online now   Reply With Quote
Old 12-05-2017, 10:26 PM   #3
TRP
Thank you, Sir!
I also just found this informative thread:
https://www.fordbarn.com/forum/showthread.php?t=12582
Old 12-06-2017, 07:24 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
And don't throw away any plugs that still fire OK, especially the 3X plugs. When the center electrode wears to a rounded end, just file it flat again. The plugs spark easier from a sharp edge than they do from a rounded tip.
Old 12-06-2017, 09:29 AM   #5
Ron in Quincy
Ron in Quincy's Avatar
make sure you have at least .025 clearest between the roter tip and the contacts in the distributor body, this provids a mutch hotter spark.
Ron in Quincy is offline   Reply With Quote
