Champion C-16 C VS Champion 3x? Hello Gang,
My car is currently running Champion C-16 C plugs. I pulled them out and they look a little worse for wear. The center electrode is noticeably worn out near the ground electrode. I picked up some Champion 3X's as recommended here. I am running a C head (with the unique water pump) on an otherwise stock motor. Should I have any concern with such a swap? I posed this question on the original 'which plug do you run' thread. It looked like it was going to get lost in a hurry. I moved it here. Thank you for your time, Ted |
Re: Champion C-16 C VS Champion 3x? With a C Head you are still running a low compression engine (at 4.6/1). The C16C plugs were a replacement for the C-4 plugs made for the C-head which were a replacement for the 3X plugs. You will be fine with the 3X plugs.
Re: Champion C-16 C VS Champion 3x? Thank you, Sir!
I also just found this informative thread: https://www.fordbarn.com/forum/showthread.php?t=12582 |
Re: Champion C-16 C VS Champion 3x? And don't throw away any plugs that still fire OK, especially the 3X plugs. When the center electrode wears to a rounded end, just file it flat again. The plugs spark easier from a sharp edge than they do from a rounded tip.
Re: Champion C-16 C VS Champion 3x? make sure you have at least .025 clearest between the roter tip and the contacts in the distributor body, this provids a mutch hotter spark.
