Old 11-19-2017, 06:00 PM   #1
3twinridges
3twinridges's Avatar
Default 48-52 239 V8 temp sender wire clip
Anybody have one of these clips on your front carb stud? I saw it in the parts book but have never seen one? Apparently it's used to hold the temp sender wire off the block?
Jonathan
3twinridges is offline   Reply With Quote
Old 11-19-2017, 06:03 PM   #2
3twinridges
Default Re: 48-52 239 V8 temp sender wire clip
Forgot to say for an F1.....
Jonathan
Old 11-19-2017, 06:27 PM   #3
rotorwrench
rotorwrench's Avatar
There were two different ignition lead support holders used in the 8BA era. One of them has a hole in between the ignition leads that the temp sender harness lead was passed through. It just depends on what year model it is as to how the harness wire was dressed.
Old 11-19-2017, 11:38 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Perhaps so but none of those bolt to the front carburetor stud, they use the manifold bolts.
Old 11-20-2017, 06:47 AM   #5
fortyfords
fortyfords's Avatar
I would think the carb stud is wrong because the base of the carb is heated and the manifold would be a little cooler but I don't know for sure.
fortyfords is offline   Reply With Quote
Old 11-20-2017, 09:17 AM   #6
rotorwrench
I don't recall seeing one with a clip on a carb stud. Carb studs have to be tightened pretty well and I never liked putting anything on one that didn't absolutely have to be there. I prefer the manifold mounted supports anyway.
Old 11-20-2017, 10:42 AM   #7
Ross F-1
Ross F-1's Avatar
My engine has the "cloverleaf" ignition wire supports, and the wire is run thru the center of those.
JB got a reply from someone on another forum who has what appears to be a factory clip, on the front carb stud. Never seen one myself.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-20-2017, 12:00 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
There Ya'go. Obviously was used on early production that did not have the clover leaf wire supports.
Old 11-20-2017, 12:21 PM   #9
rotorwrench
At least that clip is designed to be out of the way. It can be pain enough to get some carb nuts off and on. That engine definitely has the early type ignition lead supports.
