48-52 239 V8 temp sender wire clip Anybody have one of these clips on your front carb stud? I saw it in the parts book but have never seen one? Apparently it's used to hold the temp sender wire off the block?
Jonathan |
Re: 48-52 239 V8 temp sender wire clip Forgot to say for an F1.....
Jonathan |
Re: 48-52 239 V8 temp sender wire clip There were two different ignition lead support holders used in the 8BA era. One of them has a hole in between the ignition leads that the temp sender harness lead was passed through. It just depends on what year model it is as to how the harness wire was dressed.
Re: 48-52 239 V8 temp sender wire clip Quote:
Re: 48-52 239 V8 temp sender wire clip I would think the carb stud is wrong because the base of the carb is heated and the manifold would be a little cooler but I don't know for sure.
Re: 48-52 239 V8 temp sender wire clip 1 Attachment(s)
JB got a reply from someone on another forum who has what appears to be a factory clip, on the front carb stud. Never seen one myself. |
Re: 48-52 239 V8 temp sender wire clip At least that clip is designed to be out of the way. It can be pain enough to get some carb nuts off and on. That engine definitely has the early type ignition lead supports.
