Old 09-05-2017, 09:48 AM   #1
fixitphil
Default Amp Meter ??
I'm installing a 12v system (60 amp alt) in my '31 Sport Coupe and have been advised by a competent club member that the stock amp meter will have a tendency not to hold up, that I should replace it with a voltmeter. any thoughts and have any of you experienced that problem?
Thanks, Phil
FixitPhil
fixitphil is offline   Reply With Quote
Old 09-05-2017, 10:03 AM   #2
duke36
Default Re: Amp Meter ??
We have 12 volt , 60 amp alt and Zipper Ignition. So far no issues with 30 amp. ammeter.
Old 09-05-2017, 10:06 AM   #3
fixitphil
Thanks Duke. I think the stock amp meter is 15 volt. Maybe that is the answer.
FixitPhil
Old 09-05-2017, 10:49 AM   #4
Jim Brierley
You'll have no trouble with the stock amp meter.
Old 09-05-2017, 10:53 AM   #5
RawhideKid
Hey Phil, I use both a volt and 30 amp meter. But I only have a 35amp alternator, but the ammeter is not voltage sensitive, so use what ya got. I would however install a 30amp meter as opposed to the stock 20 amp meter, less strain on the needle.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 09-05-2017, 11:04 AM   #6
fixitphil
Thanks guys. This info really helps.
FixitPhil
Old 09-05-2017, 04:04 PM   #7
Charlie Stephens
On my '32 I placed a jumper wire across the the posts on the ammeter so only 1/2 (approx) of the current goes through the meter. Now all I have to do is double the amps in my head when reading the meter. You may be able to do this at the junction box depending on your wiring diagram. Read up on the quality of the reproduction ammeters before you make your decision.
Charlie Stephens
Old 09-06-2017, 07:04 AM   #8
fixitphil
Thanks to all of you for the help.
FixitPhil
Old 09-06-2017, 01:02 PM   #9
marc hildebrant
marc hildebrant's Avatar
Charlie Stephens
The gauge of the wire that you use for the added wire determines how the amp meter scale is changed. High number does less, low number does more. The electrical term for the added wire is a "shunt".
Marc
marc hildebrant is offline   Reply With Quote
