Old 08-05-2017, 11:15 AM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Another 11A post ......from Bubba
I know there are quite a few posts on this but the last couple weeks there were a few questions concerning the 11A helmet distributor. This was from one of those posts with a no start broken point spring question...
In the interest of time i will just throw it out there with some pics.
Questions ????
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-05-2017, 11:17 AM   #2
BUBBAS IGNITION
Default Re: Another 11A post ......from Bubba
some more........
[email protected]
Old 08-05-2017, 11:51 AM   #3
alanwoodieman
Nice job. I still from time to time find a 11A distributor. I believe the old timers knew about this advantage. How much maximum advance will a flat head take and run good?
Old 08-05-2017, 12:34 PM   #4
BUBBAS IGNITION
We found on our Bonneville flathead we lost power any above 24-26 degrees.
The 11A at 22 degrees seems to work very well.......
[email protected]
Old 08-05-2017, 06:32 PM   #5
Phil Gillespie
Phil Gillespie's Avatar
Looking forward to receiving my unit recently put on order with Bubba.
An 11A with a Vertex magneto condenser along with a rebuilt "Skip" coil.
This set up should give a noticeable difference along with a recently fitted Uncle Max Stromberg 97. A little bit of a Spring Clean tune up for the 39 Standard Coupe.
These people provide excellent service considering we are located Down Under!
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 08-05-2017, 09:41 PM   #6
alanwoodieman
I found my best overall response was 22 degrees advance. Thanks
Old 08-06-2017, 06:40 AM   #7
2manycars
2manycars's Avatar
Your web site is nice, but the title is Home, so when someone makes a bookmark, it does not say Bubba, but it just says Home, which might be difficult to understand when searching book marks for Bubba.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 08-06-2017, 10:44 AM   #8
BUBBAS IGNITION
Bill, I dont know how to change that , however when i use bookmarks i an always change the name to Bubbas etc.
Thanks for the comments.
[email protected]
Old 08-06-2017, 10:59 AM   #9
Biggles
Biggles's Avatar
Your experience is always refreshing. I would be very interested in the details of that advance curve - static, 1500, 2000, 2500, all in at 3000?
How do you think that should be modified on a blown flathead?
Biggles is offline   Reply With Quote
Old 08-09-2017, 02:27 PM   #10
grumppyoldman
grumppyoldman's Avatar
Sure looks good, hope that's mine. Al
grumppyoldman is offline   Reply With Quote
Old 08-09-2017, 02:35 PM   #11
BUBBAS IGNITION
Probably is yours, went to Texas.....
[email protected]
Old 08-09-2017, 04:12 PM   #12
2manycars
2manycars's Avatar
You need to get into the code for the web site. The name of the site is near the top of the code page. When I used a PC, I could look at it by clicking "view source", but my mac does not have that feature.
Bill
www.brauchauto.com
Old 08-09-2017, 06:03 PM   #13
grumppyoldman
Very good I'll be at the mailbox in the morning, Thanks for the prompt job, can hardly wait to get it on the road. Al
