Old 06-04-2017, 03:47 PM   #1
d.
Default steering column throttle lever/ stiff
I just bought a '29 open PU, and the throttle lever on the steering column is totally not moving. It is unhooked on the firewall side, so it is definitely a steering column issue.
I have shot it with WD-40 for a week now and tapped it with a rubber hammer...no improvement.
The spark lever works fine, only the throttle lever is the problem.
Any suggestions are welcome.
thank you
d. is offline   Reply With Quote
Old 06-04-2017, 04:48 PM   #2
lindy williams
Default Re: steering column throttle lever/ stiff
that is not an easy fix. the diecast bushing in the upper steering column has swelled from intergranular corrosion and is making the throttlle lever a very tight fit. The bushing will have to be replaced by removing the steering column and driving out the bushing and replacing it. Sorry.
lindy williams is offline   Reply With Quote
Old 06-04-2017, 05:07 PM   #3
SeaSlugs
SeaSlugs's Avatar
Throw your WD-40 in the far back of the garage and get a real penetrating oil like Kroil, PB blaster, liquid wrench and try one of those. But yes th eupper bushing is whats swelled and stuck. Soak soak soak with legit penetrating oil for a week and it will move.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-04-2017, 07:28 PM   #4
Big hammer
What SeaSlugs said ! WD-40 is good for removing bugs and tar thats about it!
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 06-04-2017, 10:58 PM   #5
SeaSlugs
SeaSlugs's Avatar
and removing grease off your fingers and lighting off potato guns! other than that its rather worthless IMO....
Old 06-04-2017, 11:02 PM   #6
Dodge
And displacing water for which it originally designed for.
Dodge is offline   Reply With Quote
Old 06-05-2017, 07:13 AM   #7
2manycars
2manycars's Avatar
Yes, hense the name WD40... water displacing40.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 06-05-2017, 07:23 AM   #8
JDupuis
JDupuis's Avatar
D. Is the steering wheel off? If so, oil and compressed air may help. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 06-05-2017, 08:48 AM   #9
100IH
Also, if they have been re-plated, the plating should not go down into the bushing. It can be removed but only by first removing the rod.
100IH is offline   Reply With Quote
Old 06-05-2017, 04:07 PM   #10
d.
thank you guys...WD has been chucked, now using PB blaster. Steering wheel is mounted, car is in use.
I will give it a week and report back...any other ideas?
thanks all.
