Old 03-30-2017, 07:08 AM   #1
mountinpie
mountinpie's Avatar
Default Always Learning
It's amazing how much we can learn from each other just by reading miscellaneous posts. After reading a post from Blockhead called "Sometimes..." I realized that I have this light bar on the shelf. While I haven't starting thinking about the light bar, my plan was to use the cast light bar, rather than the stamped one, just because it looked more original. Thanks for saving me from making that mistake. This light bar is cracked on one side and previously repaired on the other, but worth saving, right?
mountinpie is offline   Reply With Quote
Old 03-30-2017, 07:14 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Always Learning
Sure looks to me like its worth saving. Looks like a fairly easy fix to get it looking pretty again.
Old 03-30-2017, 11:45 AM   #3
pooch
pooch's Avatar
...edited,
pooch is offline   Reply With Quote
Old 03-30-2017, 01:03 PM   #4
Tiny
Tiny's Avatar
Very rare piece there. Only used for June til September of 30 or there abouts. I would fix it and use it if it's correct for your car
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 03-30-2017, 03:06 PM   #5
mountinpie
mountinpie's Avatar
Bob C suggested in a post earlier this year that it was used May to August 1930. The car is late-May. Can anyone else confirm the dates these bars were used?
Old 03-30-2017, 03:56 PM   #6
Tiny
Tiny's Avatar
That could be correct. I'm going off memory. It's listed in the judging standards
Blackwall Panthers
Nor Cal chapter
Old 03-30-2017, 03:58 PM   #7
Jason in TX
Jason in TX's Avatar
Interesting! I didn't know about the stamped light bar either. Love learning new things!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 03-30-2017, 04:38 PM   #8
Jim Mason
Jim Mason's Avatar
If you like this kinda stuff...try the restoration guidelines and judging standards
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 03-30-2017, 05:10 PM   #9
DougVieyra
DougVieyra's Avatar
Post # 1: "This light bar is cracked on one side and previously repaired on the other."
- Makes it easy to see why Ford dropped this design and replaced it with a heftier designed headlite bar.
DougVieyra is offline   Reply With Quote
