Old 02-08-2017, 12:34 PM   #1
A31Woody
A31Woody's Avatar
Default Looking for a source for vulcanized rubber body pad material
I'm looking to replace the rubber pad between the frame and my station wagon body. As you can see from the picture, the current rubber is toast. Does anyone have a source for vulcanized rubber material that I could use to re-create the original pads. Also, any ideas as to how thick they should be?
A31Woody is offline   Reply With Quote
Old 02-08-2017, 12:45 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Looking for a source for vulcanized rubber body pad material
Wouldn't the station wagon have used the same as other cars? If so, wouldn't the kit from the suppliers work?
Old 02-08-2017, 12:53 PM   #3
CarlG
CarlG's Avatar
Find an outfit near you that does repair work on conveyer belts. I would imagine they have a ton of stuff they would be all too willing to let you haul off and make your own pads.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-08-2017, 02:03 PM   #4
JDupuis
JDupuis's Avatar
Sidewall of an old tire?
Slice up some old rubber rain boots. Jeff
JDupuis is offline   Reply With Quote
Old 02-08-2017, 02:18 PM   #5
Keith True
Keith True's Avatar
Boiler gasket material works nice.Very stable under pressure,in all temperatures.Has a fabric core so it won't squeeze out.I haven't seen any rubberized conveyer belt that is thin enough for this use.I have used belting as shims to mount a 29 radiator on a 31 crossmember,it was 3/8 thick.I can't be sure,but for some reason 1/8 thick comes to mind for original pads.
Old 02-08-2017, 02:36 PM   #6
MikeK
MikeK's Avatar
Ask at your local grocery or big-box store. Those checkout conveyor belts get replaced whenever the metal lacing starts to rip out. Most are 3/32 or 1/8 thick. I scored several like new belts with buggered-up lacing a few years ago.
MikeK is offline   Reply With Quote
Old 02-08-2017, 02:42 PM   #7
Slowplane
Slowplane's Avatar
I used conveyor belt material from Tractor Supply on my 150A. I think its about 3/16" thick. less than $20.
I had first bought the pad kit that the vendors sell, and, right outta the box, I saw it was not acceptable. (thin, unreenforced, and "cheesy"). I think the Rest. Guide has the dimensions listed.
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 02-08-2017, 02:45 PM   #8
A31Woody
A31Woody's Avatar
Thanks. I'll have to see where I can find some locally. I need to order a set of the guidelines... not planning on having the car judged, but I'm realizing there is a lot of info in there...
Old 02-08-2017, 02:47 PM   #9
lindy williams
I used rubber cut from the side wall of an old Model A tire. 1/4 inch thick and plenty of cord in it like the originals. The pads sold by the parts suppliers has no cord in it and is too thin.
lindy williams is offline   Reply With Quote
Old 02-08-2017, 02:59 PM   #10
CarlG
CarlG's Avatar
You might also check out McMaster Carr:
https://www.mcmaster.com/#standard-c...belts/=169oi0i
Alaskan A's
Old 02-08-2017, 03:19 PM   #11
A31Woody
A31Woody's Avatar
Lots of great suggestions. Thanks as always everyone for your help.
Old 02-08-2017, 05:37 PM   #12
Drive Shaft Dave
I went to a conveyer belt company and the guy gave me a 1 foot wide by 15 foot roll for free.
Drive Shaft Dave is offline   Reply With Quote
Old 02-08-2017, 05:54 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I found a semi truck mud flap laying on the side of the road, and it was just right for making shims. It even had the fabric reinforcing in it.
Also, there is a conveyor belt company close to me, and he gave me some belting for free, when I mentioned it was for a Model A.
Old 02-08-2017, 07:32 PM   #14
Dan Partain
Dan Partain's Avatar
I got some good rubber in Sacramento - Many thicknesses, not inexpensive, but it's good reinforced material.
Capital Rubber
SACRAMENTO
1725 19th Street, Sacramento, CA 95811
Phone (916) 498-1800 / (800) 662-1800
Fax (916) 498-1818
STOCKTON
1110 South Wilson Way, Stockton, CA 95205-7064
Phone (209) 464-1200 / (800) 624-1210
Fax (209) 464-2773
Dan Partain is offline   Reply With Quote
Old 02-08-2017, 07:34 PM   #15
A31Woody
A31Woody's Avatar
Capital Rubber
SACRAMENTO
Fax (916) 498-1818
STOCKTON
Fax (209) 464-2773
Thanks Dan. I've been itching to get up to Vintage Ford for a while. Maybe a trip to sack town is in order.
Old 02-08-2017, 07:49 PM   #16
redmodelt
redmodelt's Avatar
More good information, thank for the tips.
Old 02-08-2017, 08:11 PM   #17
Midwest Tin
Midwest Tin's Avatar
Hi,
I found reinf. rubber material at McMaster-Carr. Part#s in photos. Hope this helps.
Jim
Midwest Tin is offline   Reply With Quote
Old 02-08-2017, 08:44 PM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
How about rubber BOOT/SHOE soles? I've also seen shoe soles made from TIRE TREADS.
Bill Hiker
"THE ASSISTANT GURU OF STUFF"
Old 02-08-2017, 09:04 PM   #19
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
When you say you want to re-create the original pads, they were originally cotton reinforced ...which as you probably already know, is NOT what the vendors sell. Most conveyor belting is too thick from what I found. I have some prints of pads for Ford-produced bodies, but I am not sure the thickness is the same for the 150-B. I would start by contacting Tim Johnstone to get the correct thickness dimension if you are truly trying to re-create with authenticity.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-08-2017, 11:14 PM   #20
Stew Masche
Stew Masche's Avatar
I also recently bought a small roll of reinforced belting from my local Tractor Supply store. I would agree it is about 3/16" thick, and is quite inexpensive.
It is very comparable in thickness to the non-reinforced pads supplied by the vendors. I am very pleased with the results on my project.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
