Old 11-23-2016, 07:52 AM   #1
OHV DeLuxe
Default Which wide five drums on stock 1932
Which wide five drums will fit stock 1932 if any. 1936?
Thanks.
OHV DeLuxe is offline   Reply With Quote
Old 11-23-2016, 02:37 PM   #2
Brian
Brian's Avatar
Default Re: Which wide five drums on stock 1932
Correct
Old 11-23-2016, 03:34 PM   #3
Speedy Canuck
Speedy Canuck's Avatar
Wasn't 1936 a one year only with a longer snout?
- Speedy
"Now you listen to me young man ... There'll be no hopped up jobs around here"
Speedy Canuck is offline   Reply With Quote
Old 11-23-2016, 03:42 PM   #4
skidmarks
skidmarks's Avatar
37 to 39 are a better choice. 36 will fit but the bearing and seal are different amd more expensive
skidmarks is offline   Reply With Quote
Old 11-23-2016, 05:20 PM   #5
Brian
Brian's Avatar
Sorry, I disagree that 37-39 are a better choice. The length of the 32 stub axle is close to that of the 36 and the offset of backing plate is the same. As Canuck says; 36 has a longer snout. [32 has the long snout too] OHV Deluxe asked about stock 32, I assume he means to retain the mechanical brakes. ??
Old 11-23-2016, 07:37 PM   #6
skidmarks
skidmarks's Avatar
Sorry i was thinking of just the rear.the front is longer only on the 36
Old 11-23-2016, 08:11 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
'36 -'39 rears should all work. Only '36 will work on the front.
John
Old 11-24-2016, 04:43 AM   #8
OHV DeLuxe
Great answers! thanks!
Old 01-13-2017, 01:26 PM   #9
Fred A
Fred A's Avatar
Something wrong with the answers to this question. I would double check before committing too much. Fred A
Fred A is offline   Reply With Quote
Old 01-13-2017, 01:46 PM   #10
Bruce Lancaster
'32-35 have the long spindle up front...'36 has short spindle. It has same bolt pattern as '32-5, but spindle length same as '37-48. So, I think, you would use a bearing spacer on the '32 just as with a hydraulic conversion. Would '36 drum then have its working surface too deep to fit '32? I do believe it is a deeper drum then the earlies or the '37-48's. I think...this is all getting confusing! At any rate, '36 spindles are oddballs.
Old 01-13-2017, 04:00 PM   #11
Brian
Brian's Avatar
Not confusing at all. 36 front drums will fit up to 32 spindles. Only thing is the 32 brake shoes are narrower.
Old 01-13-2017, 04:44 PM   #12
Bruce Lancaster
'36 drums will require a bearing spacer to fit '32-5, just as with '37-48 drums. '36 went to the short spindle.
