Just looking thru the Les Andrews Mechanic's Handbook on reinstalling the brake drums and there is no mention of packing the rear wheel bearings with W/B grease, as is instructed on the front bearings & hubs, I have always packed the rears the same as the front, is this an oversight in the book or am I incorrect on this procedure?
Pack the bearings. You can add a shot of grease using the zirk on the end of the housing once in a blue moon also but don't overdo it.
Yep, pack 'em.
OK, Thanx !
DON'T use that grease fitting!!!! It's like dealing with a FICKLE WOMAN!!!! It was later deleted, along with the FICKLE WOMAN.
Bill Cautious
Thanx guys, will pack them upon installation this weekend. Grease seal with the writing visible from inside the drum, not turned into the bearing area.
use a heavy fibre wheel bearing grease. the thinner modern disc brake greases will run out and be useless fairly quickly. I like the Sta lube extra heavy duty wheel bearing grease. It comes in a green can. Can be found at many NAPA stores
I use this in the rear wheel bearings 28-48. Fronts I use std wheel bearing lube Larry |
I use that Mystic JT6 red/pink grease that Tom likes. Sure is some stringy stuff and clings to everything. Comes in standard 1 lb can or in standard sized tubes. Each side of my AA's rear bearings I jammed about 3/4-1 can of grease in.
I used the same stuff, just not nearly that much! Wayne
A buddy had a '55 Studebaker that needed to have the rear bearings packed just like the fronts, and he didn't realize this. There was no grease zerk.
On the way home from a trip to Burlington, Iowa one of them overheated and toasted on him, seized up, stopping him about one block from home after a 100 mile round trip! Yeah I'd pack 'em good and then make them part of your regular servicing like Ford says to do. I don't know if they pre-packed them at the factory I assume they probably did. Can't hurt. |
Thanx for the tip on the heavy fiber wheel bearing grease. I'll pick some up at Napa and put it to use.
#13 |
Here is the Napa number. The fibers pull the grease under the straight rollers.
https://www.napaonline.com/p/SLRSL3131 John |
#14 |
Excellent thanks John for posting the can image and link
Larry |
#15 |
Prior to putting it together run some grease through the "zerks" to ensure they function or must be replaced.
#16 |
Good call on that grease...Amazon sells it too.
1929 Tudor |
