The Ford Barn
-   -   Rear Wheel Bearings (https://www.fordbarn.com/forum/showthread.php?t=206679)
JtownJoe 10-10-2016 06:25 PM
Rear Wheel Bearings
Just looking thru the Les Andrews Mechanic's Handbook on reinstalling the brake drums and there is no mention of packing the rear wheel bearings with W/B grease, as is instructed on the front bearings & hubs, I have always packed the rears the same as the front, is this an oversight in the book or am I incorrect on this procedure?
J Franklin 10-10-2016 06:40 PM
Re: Rear Wheel Bearings
Pack the bearings. You can add a shot of grease using the zirk on the end of the housing once in a blue moon also but don't overdo it.
Patrick L. 10-10-2016 06:42 PM
Yep, pack 'em.
JtownJoe 10-10-2016 07:06 PM
OK, Thanx !
BILL WILLIAMSON 10-11-2016 09:50 AM
DON'T use that grease fitting!!!! It's like dealing with a FICKLE WOMAN!!!! It was later deleted, along with the FICKLE WOMAN.
Bill Cautious
Jim Brierley 10-11-2016 11:54 AM
What Bill says is right. A lot of guys install that inner seal facing the center section, this is backwards because that seal is meant to direct the grease from the zerk into the wheel bearing. Just pack it now, and again in a couple of years.
JtownJoe 10-11-2016 10:34 PM
Thanx guys, will pack them upon installation this weekend. Grease seal with the writing visible from inside the drum, not turned into the bearing area.
larrys40 10-12-2016 07:54 AM
use a heavy fibre wheel bearing grease. the thinner modern disc brake greases will run out and be useless fairly quickly. I like the Sta lube extra heavy duty wheel bearing grease. It comes in a green can. Can be found at many NAPA stores
I use this in the rear wheel bearings 28-48. Fronts I use std wheel bearing lube
Larry
SeaSlugs 10-12-2016 09:06 AM
I use that Mystic JT6 red/pink grease that Tom likes. Sure is some stringy stuff and clings to everything. Comes in standard 1 lb can or in standard sized tubes. Each side of my AA's rear bearings I jammed about 3/4-1 can of grease in.
C26Pinelake 10-12-2016 09:11 AM
I used the same stuff, just not nearly that much! Wayne
Jeff/Illinois 10-12-2016 09:59 AM
A buddy had a '55 Studebaker that needed to have the rear bearings packed just like the fronts, and he didn't realize this. There was no grease zerk.
On the way home from a trip to Burlington, Iowa one of them overheated and toasted on him, seized up, stopping him about one block from home after a 100 mile round trip! Yeah I'd pack 'em good and then make them part of your regular servicing like Ford says to do. I don't know if they pre-packed them at the factory I assume they probably did. Can't hurt.
JtownJoe 10-12-2016 10:27 PM
Thanx for the tip on the heavy fiber wheel bearing grease. I'll pick some up at Napa and put it to use.
john in illinois 10-13-2016 07:05 AM
Here is the Napa number. The fibers pull the grease under the straight rollers.
https://www.napaonline.com/p/SLRSL3131
John
larrys40 10-13-2016 09:18 AM
Excellent thanks John for posting the can image and link
Larry
Bruce Adams 10-13-2016 09:45 AM
Prior to putting it together run some grease through the "zerks" to ensure they function or must be replaced.
krzewinskibe 10-14-2016 06:46 AM
Good call on that grease...Amazon sells it too.
