Old 09-04-2016, 08:37 AM   #1
Gino
Default 29/30 Tranies the same?
Hi, will a 29 Trany fit to a 30 with no problems? Thanks Gino
Gino is offline   Reply With Quote
Old 09-04-2016, 08:40 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 29/30 Tranies the same?
Yes, but the parking brake in 29 was located in front of the shift lever for the first half of the year.
Also check the spacing for the rear bearing retainer. Earlier transmissions had uneven spacing for the 6 bolts, and people mix and match parts, so you may have to change the retainer.
Old 09-05-2016, 05:44 AM   #3
Gino
Thank you sir, I'll look into this further before I buy.
Old 09-05-2016, 07:47 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
1928 - 1931 transmissions have the same fit and function, but not the same form. Ford made several internal changes to the transmission during Model A production, and you can see these changes in the service bulletins.
Bob Bidonde
