Old 08-25-2016, 05:01 AM   #1
russcc
Default 59 AB Starter Bendix drive
I removed the starter Bendiix drive, cleaned it , replaced the spring and now ready to reassemble.
Do you leave the spiral gear area as is, or is there a proper, none greasy lube that should be used. I believe you do not want something that holds dirt and debris like grease or oil in the spiral gear. Thank you Fordbarners.
