Old 05-22-2016, 01:44 PM   #1
ratamahata
ratamahata's Avatar
Default Model A banger engine!
I want to tell us guys... Found an old model A ford engine with a lot of history in racing in my city because belonged to a man , who in the seventies ... competed in the category "Limited 31 " along country roads ...
Model A block with a system of forced lubrication , from a hole under the bolt that holding the oil pump on the block, Oil pump have some work for this, model B head and waterpump , drilled A crankshaft , reground B camshaft , has also a hole to place a fuel pump! Lightened flywheel to!
ratamahata is offline   Reply With Quote
Old 05-22-2016, 01:46 PM   #2
ratamahata
ratamahata's Avatar
Default Re: Model A banger engine!
Some cracks welded in both intakes holes!
Old 05-22-2016, 03:57 PM   #3
Mikeinnj
Mikeinnj's Avatar
What is the category "Limited 31 " ???
Mikeinnj is offline   Reply With Quote
Old 05-22-2016, 06:14 PM   #4
ratamahata
ratamahata's Avatar
The limited 31 before called fuerza limitada 31 was a category of automobile racing! Cars must be up to the 1931 model, 4 o 6 cylinder! Any brand! Great engines and car like the Buick Marcheti with 7 mains, Chrysler , continental, Chevrolet, Ford! And others!
Old 05-23-2016, 10:37 AM   #5
Jim Brierley
I've never seen an engine like yours! It has a fuel pump located in the rear half of the engine, and a cam to match. Model A engines in the US had no fuel pump, B engines had a pump located in the front half of the engine! Is this an Argentine-built block???
Old 05-23-2016, 11:18 AM   #6
ratamahata
ratamahata's Avatar
Jim! My thoughts is the hole for the fuel pump was maded by the guy! In Argentina model A was RHD! Maybe for that reason de camshaft have the lobe in that position!
Enviado desde mi XT1068 mediante Tapatalk
Old 05-23-2016, 11:22 AM   #7
ratamahata
ratamahata's Avatar
Or maybe hole for pump and lobe was maded! Aftermarket!
Old 05-24-2016, 08:36 AM   #8
ratamahata
ratamahata's Avatar
Bump for the day!
Old 05-24-2016, 10:27 AM   #9
emf
emf's Avatar
Was the hole for the 'fuel pump' on the back of the block used for an external oil pump instead???
Frank
emf is offline   Reply With Quote
Old 05-24-2016, 10:43 AM   #10
ratamahata
ratamahata's Avatar
Frank
Yes I think! This category of automobile racing only allow cars to the 1931 year, any brand! Not later models, so a 1932 model B block wasn't an option! I don't know the rules over engine modifications! I bought the engine in parts, it's supposed that some ten years ago the car was entire with the mechanicals parts to!
If you think about the seventies in my country, they would be some speed parts or compression heads available from the US?
Well this guy managed to build up this engine with a model C head and a 33-34 water pump! Well there's a problem with that pump, just a one inch short! So again I trying to figure if the pump was an original part of the original engine! Would have a modified fun to align?
