Old 01-30-2016, 09:39 PM   #1
wrndln
Default Lock washers on the rear transmission bearing retainer
When I dismantled the transmission I am now rebuilding, there were lock washers used on the four bolts that fasten the rear bearing retainer to the transmission. The washers were Ford lock washers that have the serrations on them, not modern lock washers someone decided to install. The bolts have safety wire to keep them from coming loose. There is a slight concern that if the bolts go in too far they could possibly interfere with the cluster gear, thus the lock washers. In Les Andrews volume 1 (picture below), it says nothing about lock washers. I have heard there are errors in Les' book, so I thought I would check here to see what Fordbarn people think. It may not make any difference either way, I just want to do it the way Ford did it.
Added note: All the bolts used on the transmission had lock washers on them.
Rusty Nelson
Old 01-30-2016, 09:59 PM   #2
wrndln
Default Re: Lock washers on the rear transmission bearing retainer
Vince,
You are probably right. In Mike Isbell's Standard Hardware booklet is shows 7/16" lock washers along with the 7/16-20 bolts under the transmission section. The lock washers might be used to insure the bolts don't go into the case too far. I can't find my PPL.
Rusty Nelson
Old 01-30-2016, 10:27 PM   #3
Mitch//pa
If it's just to take up the length of the bolt why not use shorter bolts or just flat washers... I think it's to lock in the bolt
Old 01-30-2016, 11:07 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, use lock washers, A-22300, four of them.
Old 01-30-2016, 11:25 PM   #5
J Franklin
J Franklin's Avatar
I have dismantled over 7 A transmissions and all had lockwashers installed
Old 01-31-2016, 12:35 AM   #6
wrndln
Thanks to all that responded. Lock washers it is.
Rusty Nelson
Old 01-31-2016, 12:39 PM   #7
katy
katy's Avatar
What are: "The washers were Ford lock washers that have the serrations on them"? (A-22300 ?)
Are they internal or external star washers? Or? I looked on Bratton's site and all I saw was split lockwashers.
Old 01-31-2016, 02:53 PM   #8
Tom Wesenberg
They are regular split lock washers, but most of the ones from those days have the split at an angle \ and have the outside edge with a design of vertical lines llllllllllll, or xxxxxxxx pattern.
Old 02-01-2016, 11:25 AM   #9
katy
katy's Avatar
Thanks Tom, this older fellow learned something new today. Methinks I'll go check my stock of old non-plated lock washers to see ifn there's any of that type in there.
Old 02-01-2016, 10:00 PM   #10
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
For ever 4 Are you mad at Les rag i like it
Indiana A. Lover is offline   Reply With Quote
