Old 01-08-2016, 02:44 PM   #1
bonanza7369
Default door handle installation
I have new interior door panels for my 56 ford and need to install the door handles and window cranks back on. Were does the big spring go? does it need to be on behind the panels with the small end out toward the handle?
thanks Bill
bonanza7369 is offline   Reply With Quote
Old 01-08-2016, 02:53 PM   #2
mikhett
Default Re: door handle installation
Put door panel on first,then big spring end against panel little end out against handle.
mikhett is offline   Reply With Quote
Old 01-08-2016, 07:51 PM   #3
Lanny
Lanny's Avatar
No, the spring gets put on first, slide it over the the splined shaft,
small end inward, and big end of spring will be up against the
upholstery panel, so that the panel will stay taught against the
escutcheon (small round spacer between handle and upholstery).
Escutcheon is # 23370 in Rons picture.
So you have the spring, door panel, escutcheon, then the handle.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 01-08-2016, 10:20 PM   #4
paul2748
paul2748's Avatar
The 56 Fords (like the TBirds) didn't have an escutcheon as far as I know - the part # 23370 is a plastic washer that goes between the panel and the handle, but otherwise the sequence is correct. The 23370's are available.
My 54 ford does not have any escutcheons - I think Ford dropped them starting in 1952.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-09-2016, 11:22 AM   #5
raceron1120
raceron1120's Avatar
Originally Posted by paul2748 View Post
The 56 Fords (like the TBirds) didn't have an escutcheon as far as I know - the part # 23370 is a plastic washer that goes between the panel and the handle, but otherwise the sequence is correct. The 23370's are available.My 54 ford does not have any escutcheons - I think Ford dropped them starting in 1952.
Hmmm.... interesting. When I pulled mine, it had those plastic washer pieces.
But over the years who knows how many times it or any of them might've been pulled apart and put back together?
According to the parts book I have, they are used on many 53-56 Body styles. Full Part # is BA-7023370-A.
raceron1120 is offline   Reply With Quote
Old 01-08-2016, 03:17 PM   #6
raceron1120
Parts book illustration - might help:
Old 01-09-2016, 11:52 AM   #7
bonanza7369
confused drawing shows spring with big end out. is this behind the door panel? other post says put in out outside of panel with big end in.
Old 01-09-2016, 12:34 PM   #8
Lanny
Lanny's Avatar
You want to RE READ my post above !
Old 01-09-2016, 08:13 PM   #9
paul2748
paul2748's Avatar
Lanny's correct - spring goes between the door and the panel
Big end toward the panel
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-09-2016, 09:58 PM   #10
frank long island
frank long island's Avatar
yup small end towards regulator or door handle mount big end against door panel its a tight fit
frank long island is offline   Reply With Quote
