Old 03-09-2016, 09:26 AM   #1
41plym
Default tube
I'm buying new tires. Who's tube is best?
41plym is offline   Reply With Quote
Old 03-09-2016, 09:51 AM   #2
Mitch//pa
Default Re: tube
Brattons. They have them made for themselves specially...
Old 03-09-2016, 10:03 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: tube
Has anyone ever put GREEN-SLIME in your Model A tubes?
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-09-2016, 11:23 AM   #4
41plym
Default Re: tube
metal stem yes or no?
Old 03-09-2016, 11:30 AM   #5
C26Pinelake
Default Re: tube
Several posts on this subject. Brattons is the tube of choice. Wayne
C26Pinelake is offline   Reply With Quote
Old 03-09-2016, 11:43 AM   #6
Mitch//pa
Default Re: tube
Yes
Old 03-09-2016, 12:01 PM   #7
John Stone
John Stone's Avatar
Default Re: tube
Bill W.
Saw one car that had it and after he had a flat, it was a nasty mess. Said he put it in because of a slow leak. It fixed that but after he hit a nail it didn't fix that.
John Stone is offline   Reply With Quote
Old 03-09-2016, 12:05 PM   #8
Mitch//pa
Default Re: tube
Bill W.
You'll have major balance issues
Old 03-09-2016, 12:27 PM   #9
Phil Brown
Phil Brown's Avatar
Default Re: tube
3 OR 4 oz. of antifreeze (coolant) in the tubes or tires will stop those slow leaks and not make a mess of things in the future
Phil Brown is offline   Reply With Quote
Old 03-09-2016, 12:33 PM   #10
DougVieyra
DougVieyra's Avatar
Default Re: tube
". . . 4 oz. of antifreeze (coolant) in the tubes . . . "
_________
Interesting . . . . and novel.
And I suppose it does keep the air from freezing as well !
DougVieyra is offline   Reply With Quote
Old 03-09-2016, 12:57 PM   #11
41plym
Default Re: tube
Thanks
Old 03-09-2016, 05:01 PM   #12
fastroadster
Default Re: tube
cornstarch on tubes
fastroadster is offline   Reply With Quote
Old 03-09-2016, 05:23 PM   #13
Vin-tin
Vin-tin's Avatar
Default Re: tube
Are the ones A&L sell any good?
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 03-09-2016, 06:26 PM   #14
clo2jim
clo2jim's Avatar
Default Re: tube
I have had the A&L tubes on our Town Sedan for about a year - They even passed Judging at the Niagara Falls Meets. They installed the medal valve stems for me. We have had no problems with them
clo2jim is offline   Reply With Quote
Old 03-09-2016, 06:37 PM   #15
Mitch//pa
Default Re: tube
Don't know
Old 03-09-2016, 06:49 PM   #16
CarlG
CarlG's Avatar
Default Re: tube
Snyder's and Bratton's tubes are the same. They went in together to have them made.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-09-2016, 07:34 PM   #17
Mitch//pa
Default Re: tube
Thanks Carl I forgot about that... Here is the thread explaining it post #17 fron Don Snyder...
http://fordbarn.com/forum/showthread...Brattons+tubes
Old 03-09-2016, 08:53 PM   #18
Marvin/TN
Send a message via AIM to Marvin/TN
Default Re: tube
I have never put the slime in a tube but did put it in a lawn tractor tubless tire. In this case it did not work for me so I bought a tube and when I broke the tire down to install the tube the wheel was very rusty inside. The slime is water base and really caused the wheel to rust. It was a pain to clean up the wheel and paint it before putting the tube in and the tire back on, Never again will I use anything like that.
Marvin/TN is offline   Reply With Quote
Old 03-09-2016, 10:51 PM   #19
Herb Concord Ca
Default Re: tube
Bert's in Colorado.
Herb Concord Ca is offline   Reply With Quote
Old 03-10-2016, 08:27 AM   #20
eagle
eagle's Avatar
Default Re: tube
I bought tubes (rubber stem) from macs 5 years ago and have had no problems yet.
As far as green slime use... I've not used it in my A tires but used it in lots of others. The trick is to use much less than the directions call for, then drive right away. The slime will eventually dry to just a coating inside the tube or tire if it's tubeless. I've had great luck with it for slow leakers and never had issues with rusty rims.
