Old 01-24-2016, 06:35 PM   #1
jack leavitt
Default starter hiccup
The starter on my model A was weak when I got it about 2 months ago and about a week ago it failed I cleaned the ground connection and the battery connection on the frame and the battery terminals and that didn't fix it so I took it apart, the field windings are not grounding to the case and the armature is good the switch is also good when I hook the starter to the battery charger I can stop the starter with my hand its like the starter has no power but it spins what could be the problem?
jack leavitt is offline   Reply With Quote
Old 01-24-2016, 07:58 PM   #2
Big hammer
Default Re: starter hiccup
Try more power, battery and jumper cables
Old 01-24-2016, 08:21 PM   #3
Mitch//pa
Yes what the Hammer says..
Use a battery as it holds a load
Old 01-24-2016, 08:42 PM   #4
tbirdtbird
was the armature tested on a growler
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-24-2016, 08:47 PM   #5
Clem Clement
Clem Clement's Avatar
Brushes OK? brush spring?
commutator clean and shiny?
Old 01-24-2016, 09:29 PM   #6
jack leavitt
Armature tested good i also tried the starter on an 8 volt battery and a 12 volt battery same thing just wont turn fast or with power and the commutator is shiny clean
Old 01-24-2016, 10:57 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Are the brushes in the right holders? Someone had then 90 degrees off about a year ago. I don't think I have a picture to post, but will look.
