The Ford Barn
-   -   starter hiccup (https://www.fordbarn.com/forum/showthread.php?t=187690)
jack leavitt 01-24-2016 06:35 PM
starter hiccup
The starter on my model A was weak when I got it about 2 months ago and about a week ago it failed I cleaned the ground connection and the battery connection on the frame and the battery terminals and that didn't fix it so I took it apart, the field windings are not grounding to the case and the armature is good the switch is also good when I hook the starter to the battery charger I can stop the starter with my hand its like the starter has no power but it spins what could be the problem?
Big hammer 01-24-2016 07:58 PM
Re: starter hiccup
Try more power, battery and jumper cables
Mitch//pa 01-24-2016 08:21 PM
Re: starter hiccup
Yes what the Hammer says..
Use a battery as it holds a load
tbirdtbird 01-24-2016 08:42 PM
Re: starter hiccup
was the armature tested on a growler
Clem Clement 01-24-2016 08:47 PM
Re: starter hiccup
Brushes OK? brush spring?
commutator clean and shiny?
jack leavitt 01-24-2016 09:29 PM
Re: starter hiccup
Armature tested good i also tried the starter on an 8 volt battery and a 12 volt battery same thing just wont turn fast or with power and the commutator is shiny clean
Tom Wesenberg 01-24-2016 10:57 PM
Re: starter hiccup
Are the brushes in the right holders? Someone had then 90 degrees off about a year ago. I don't think I have a picture to post, but will look.
