Old 11-13-2015, 08:58 PM   #1
BC Texas
Default 30-31 cowl differences
Are the 30-31 coupe cowls the same as the 30-31 2door/pickup cowls. If not, what are the differences?
BC Texas is offline   Reply With Quote
Old 11-13-2015, 09:20 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: 30-31 cowl differences
Pillar height is different
Don't have exact measurements
Believe the coupe is 1" shorter but not exact
Old 11-13-2015, 09:34 PM   #3
mot
Registered User
mot's Avatar
thats correct
the coupe is 3 in from the top of the hinge
and the tudor is 4 in from the top of the hinge to the top of the pillar
mot is offline   Reply With Quote
Old 11-13-2015, 09:35 PM   #4
BC Texas
Can I effectively modify a pu cowl to fit a coupe?
Old 11-13-2015, 09:59 PM   #5
Vin-tin
Vin-tin's Avatar
I took a coupe cowl and added 1" or so (I forget) to the post height for my pickup. So yea, you can do it. The visor holes need to be moved.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 11-14-2015, 01:10 AM   #6
Dave Mellor NJ
I believe the height is the same. The top hinge is just higher on the coupe. All straight windshield closed cars use the same size windshield, header and visor.If you stand a coupe door against a wall it will be as high as a tudor/pickup door. The fordor door is shorter but that's because it doesn't have a flange at the bottom.
Dave Mellor NJ is offline   Reply With Quote
Old 11-14-2015, 12:57 PM   #7
Mikeinnj
Mikeinnj's Avatar
Amazing how you get so many conflicting answers here.....
Post #2 ,#3 & # 5 are correct.
Mikeinnj is offline   Reply With Quote
Old 11-14-2015, 03:42 PM   #8
mot
Registered User
mot's Avatar
OK
i have both a 30 tudor and a 30 coupe
in addition to the above posted figures i posted above
dimensions on a coupe door
27 3/4 wide at the belt
43 in tall
from the bottom of the door to the TOP of the lower hinge 10 in
from the bottom of the door to the top of the middle hinge 22 1/2 in
from the bottom of the door to the top of the upper hinge 40 inches
the hinges measure exactly the same on both doors
dimensions on the tudor door
29 1/4 wide at the belt
44 in tall
so a tudor door is both taller and wider than a coupe
makes it easier to get in the rear seat
Old 11-15-2015, 01:30 AM   #9
Dave Mellor NJ
Thanks for straightening me out.
