Old 10-15-2015, 07:35 PM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default 1936 Fan dimensions needed!
Reinstalling a metal 4 blade fan on a 1936 car, (had a 6V electric fan, pull type ) the fan I came up with when installed on the front of generator is to close to the radiator hoses. ( like a gap of only a 1/8" ) Need to know what is the correct length of hup/spool portion of the fan. I looked at search section of early V8 forum but did not come up with an answer, lot of info but not exact, thanks Bruce
Bruce in southern OH is offline   Reply With Quote
Old 10-15-2015, 07:48 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 1936 Fan dimensions needed!
The 35-36 book says the fan should be 15 1/2" dia, 1 3/4" deep.
Old 10-15-2015, 08:30 PM   #3
Thank you, will check mine in morning, seems like between the two hub flanges that I have only about 3/4 to 1 ", will advise, Bruce
Old 10-16-2015, 10:41 AM   #4
jacob smith
jacob smith's Avatar
my 36 is close like that
Ford
jacob smith is offline   Reply With Quote
Old 10-17-2015, 03:12 PM   #5
I found a 2" fan hub, that is measuring from back of hub ( generator end ) to back of nearest fan blade. The 2" is to long, the one I have measures 1 1/8" ( to close ). Need to know where the 1 3/4" measurement is taken from, Duece_Roadster, any idea. I believe if 2" is to long that the 1 3/4" would be correct, need to find one, any info or location would like to know, thanks Bruce
Old 10-17-2015, 03:20 PM   #6
deuce_roadster
The V8 Club restoration book only has those dimensions and not how they were measured. I would expect it would be from the mounting flange out to the farthest point. I don't have a 35 or 36 (only 32,33,40) so have no direct experience. Hopefully 36 owners on this forum will chime in.
Old 10-17-2015, 05:07 PM   #7
jacob smith
Hope this helps
Ford
Old 10-17-2015, 05:08 PM   #8
jacob smith
More
Ford
Old 10-17-2015, 07:50 PM   #9
jacob smith
This photo is of a 36 fan on the genorator. I am not sure we're to measure from but this should be right
Ford
Old 10-17-2015, 08:23 PM   #10
jacob smith, that is what I have now, to close for comfort, less than a 1/8" at closest point on upper point of radiator hose. Need fan that measures 1 3/4" duece Roadster says is in book. thanks for the photos, same way I measured, Bruce
Old 10-17-2015, 08:25 PM   #11
35fordtn
35fordtn's Avatar
33-36 is the same fan. The 37-39 has a 7/8" longer hub
Old 10-17-2015, 08:58 PM   #12
Ed Pitts
Ed Pitts's Avatar
Here are pics of the the 36 fan (first 3) and the later fan. Ed
Ed Pitts is offline   Reply With Quote
Old 10-17-2015, 09:00 PM   #13
Ed Pitts
Ed Pitts's Avatar
Here are the pics.
Old 10-17-2015, 10:23 PM   #14
Don Rogers
Don Rogers's Avatar
Bruce, Here are the correct dimensions for a 35-36 passenger car fan (40-8620-A)
Don Rogers is offline   Reply With Quote
Old 10-17-2015, 11:55 PM   #15
deuce_roadster
So Don, since you are co author of the 35-36 book, is that a misprint on page 103?
Old 10-18-2015, 06:59 AM   #16
Don Rogers
Don Rogers's Avatar
Deuce. The 1 3/4" dimension referenced in The 35/36 Book was an overall depth dimension from the base of the fan hub to the center fan rivet.
Old 10-18-2015, 07:21 AM   #17
JM 35 Sedan
JM 35 Sedan's Avatar
What Don is showing here is the most critical dimension to have or know when making sure you have the correct fan that should give you the correct clearance. If it doesn't, then something else is located incorrectly, IMO.
John
Old 10-18-2015, 07:55 AM   #18
Don
Don's Avatar
I think you have the correct fan Bruce,you might have been measuring from wrong place.give it a try!!!!!
DON P
Don is offline   Reply With Quote
Old 10-18-2015, 09:09 AM   #19
35fordtn
35fordtn's Avatar
Be sure your fan belt is not too long. With too long of a belt it can cause the clearance to be awfully close with the hoses.
Old 10-18-2015, 11:22 AM   #20
deuce_roadster
Thanks for clearing that up Don, I think your diagram in post 16 is what Bruce wanted to know.
