working on a 1939 ford coupe deluxe....hooked up the vacuum lines and the wiper motor will only move the wipers to the left and then stopped. hooked up another wiper motor and it did the same thing. any suggestions?
is there suppose to be a vacuum canister installed with this set up. Wife said she will no get into a car where the wipers don"t work...need help!!!! |
Try one or both vacuum motors out of the car without the load of the wipers and see what happens. They both may need cleaning and lubrication to work right, particularly the valve that switches the vacuum at the end of each stroke to the other side for the other direction.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
