Old 07-18-2015, 07:27 PM   #1
rlh5window
Default V8-60 water pump rebuild
I have removed both water pumps.
I have ordered rebuild kits from Macs.
How do I take them apart ?
Thanks,
Randall
rlh5window is offline   Reply With Quote
Old 07-20-2015, 09:05 AM   #2
Eckler's
Eckler's's Avatar
Default Re: V8-60 water pump rebuild
Maybe this will help.
MACSAUTOPARTS.COM
Email me direct at [email protected]
Eckler's is offline   Reply With Quote
Old 07-20-2015, 11:21 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Scott, are those directions in one of your catalogs or would they normally come with MAC's rebuild kit?
John
Old 07-20-2015, 11:21 AM   #4
KiWinUS
KiWinUS's Avatar
Be very careful removing pulley's , they break very easily . You must (as instructions say) support pump in the pulley sheave . It is also a good idea to be sure the surface that the plastic impeller rubs on is perfectly smooth & lubed.
Cheers
Tony
Old 07-20-2015, 11:47 AM   #5
Eckler's
Eckler's's Avatar
I don't think they are in the new catalog. It should come with some in the box, but i know a lot of times they fall out or the manufacture forgets to put them in.
MACSAUTOPARTS.COM
Old 07-20-2015, 05:19 PM   #6
JM 35 Sedan
Okay thanks Scott, I downloaded the info you posted to keep in my files just in case I ever need to rebuild one.
John
Old 07-21-2015, 09:27 PM   #7
rlh5window
Excellent! Thank you so much. I have two rebuild kits on the way from Macs. Hope to get them apart, cleaned and rebuilt this weekend.
Thank you.
Randall
Old 07-21-2015, 09:30 PM   #8
alan
don't be surprised if they leak a little at first, not much of a "seal" for these pumps
alan is offline   Reply With Quote
