The Ford Barn
-   -   V8-60 water pump rebuild (https://www.fordbarn.com/forum/showthread.php?t=173739)
rlh5window 07-18-2015 07:27 PM
I have removed both water pumps.
I have ordered rebuild kits from Macs.
How do I take them apart ?
Thanks,
Randall
Eckler's 07-20-2015 09:05 AM
Re: V8-60 water pump rebuild
Maybe this will help.
http://i50.photobucket.com/albums/f3...psaiiyinph.jpg
JM 35 Sedan 07-20-2015 11:21 AM
Scott, are those directions in one of your catalogs or would they normally come with MAC's rebuild kit?
KiWinUS 07-20-2015 11:21 AM
Be very careful removing pulley's , they break very easily . You must (as instructions say) support pump in the pulley sheave . It is also a good idea to be sure the surface that the plastic impeller rubs on is perfectly smooth & lubed.
Cheers
Tony
Eckler's 07-20-2015 11:47 AM
I don't think they are in the new catalog. It should come with some in the box, but i know a lot of times they fall out or the manufacture forgets to put them in.
JM 35 Sedan 07-20-2015 05:19 PM
Okay thanks Scott, I downloaded the info you posted to keep in my files just in case I ever need to rebuild one.
rlh5window 07-21-2015 09:27 PM
Excellent! Thank you so much. I have two rebuild kits on the way from Macs. Hope to get them apart, cleaned and rebuilt this weekend.
Thank you.
Randall
alan 07-21-2015 09:30 PM
don't be surprised if they leak a little at first, not much of a "seal" for these pumps
