Hi all, I posted some time back on problems of pushing back the Escutcheon to gain access to the handle drive pin. So far no luck, so I will probably have to destroy the escutcheon to remove the handle. The good book shows the correct escutcheon "40-702404" which seems to be a little different than what I've seen from Drake or C&G. Are these available. The ones currently fitted have four claws which press into the door trim and are causing some damage. Any suggestions would be appreciated.
Kpar |
The claws or pointed tabs are original and should be straight, not bent over forming a claw. Their purpose is prevent the escutcheon from rotating when the handle is moved. Because of their relatively large diameter, the '33-'34 closed car/cabriolet escutcheons add a little extra to the challenge of removing the handles. I believe that I have a few extra undamaged originals (that require plating) if that helps.
If you had put the springs in between the door uph panel and the inner door skin ,remove them.No way could I get the handle and escutcheon in far enough to put the pin in so tossed those cone shaped springs.
Have a look at this tool. One can be brought or mzke one up. leaves hands free for removing pin Phil NZ |
