The Ford Barn
-   -   33 inside Door handles (https://www.fordbarn.com/forum/showthread.php?t=173181)
Kpar 07-11-2015 11:25 PM
Hi all, I posted some time back on problems of pushing back the Escutcheon to gain access to the handle drive pin. So far no luck, so I will probably have to destroy the escutcheon to remove the handle. The good book shows the correct escutcheon "40-702404" which seems to be a little different than what I've seen from Drake or C&G. Are these available. The ones currently fitted have four claws which press into the door trim and are causing some damage. Any suggestions would be appreciated.
Kpar
DavidG 07-11-2015 11:52 PM
Re: 33 inside Door handles
The claws or pointed tabs are original and should be straight, not bent over forming a claw. Their purpose is prevent the escutcheon from rotating when the handle is moved. Because of their relatively large diameter, the '33-'34 closed car/cabriolet escutcheons add a little extra to the challenge of removing the handles. I believe that I have a few extra undamaged originals (that require plating) if that helps.
deuce lover 07-11-2015 11:53 PM
If you had put the springs in between the door uph panel and the inner door skin ,remove them.No way could I get the handle and escutcheon in far enough to put the pin in so tossed those cone shaped springs.
Phil Gillespie 07-11-2015 11:57 PM
http://www.macsautoparts.com/early_v...handles-1.html
Have a look at this tool. One can be brought or mzke one up. leaves hands free for removing pin
Phil NZ
