Old 05-17-2015, 08:01 PM   #1
Harper
Harper's Avatar
Default newbie with a 49 tudor...Flathead 6
I have worked on a lota fords but never any flat heads. mine happens to be a Flathead 6. My current issue is I can NOT get my start off. I have removed the three bolts to fly wheel, some ppl are telling me to remove the long bolts, some are saying I need to give it a nudge with a hammer...I do not want to destroy my stock starter as I believe my entire car is mostly original. Help.
thanks
Harper
Harper is offline   Reply With Quote
Old 05-17-2015, 08:06 PM   #2
JSeery
JSeery's Avatar
Default Re: newbie with a 49 tudor...Flathead 6
They are fairly heavy built, a rap with a dead-blow or rubber mallet is not going to hurt it. Not sure about the 6, the v8 has a bolt near the front in a short strap to the oil pan bolts. The long bolts will take the case loose from the end caps and the whole starter may come apart. Not sure I see any advantage to that.
Old 05-17-2015, 08:21 PM   #3
Harper
Harper's Avatar
I really want to avoid removing the long bolts. I have removed a 5/8's bolt and (2) 9/16 bolts already. Shouldn't it just come put with some persuasion?
Old 05-17-2015, 08:37 PM   #4
JSeery
JSeery's Avatar
I would think so, but I really know next to nothing about a 6 cyl. I would try a few smacks with a mallet, I can normally tell by the feel of it if it is still connected somewhere or just stuck. One feels a lot more solid that the other, at least to me it does.
Old 05-17-2015, 08:50 PM   #5
Tinker
Tinker's Avatar
What do you mean long bolts? Starter is held in by two long boltes on the starter. Yes the starter will come apart if you pull it apart. Don't do that.
Starter doesn't have any bolts that are connected to the flywheel. Just clarifying.
Old 05-17-2015, 09:08 PM   #6
JSeery
JSeery's Avatar
Thanks Tinker, I'm screwing up here, spend to much time working on mustangs!!! Flathead starters don't have mounting ears! Sorry Harper, I was thinking later starters, listen to Tinker.
Old 05-17-2015, 09:15 PM   #7
Tinker
Tinker's Avatar
Ya js I think I'm confused too on what is being asked here. might be a yblock or a 223 ohv right?
Old 05-17-2015, 10:00 PM   #8
Harper
Harper's Avatar
ok I stand corrected too, its not connected to the flywheel, but the bell housing
I have three bolts that were connected to bell housing and they have been removed. Now I am curious if maybe I have a later model engine? its still a flathead straight 6...
Old 05-17-2015, 10:05 PM   #9
Tinker
Tinker's Avatar
Post a picture of the engine if you will. I't be very helpful. Thanks
Old 05-17-2015, 10:15 PM   #10
r_reed
r_reed's Avatar
if the flathead 6 starter is like the flathead 8 starter, the two long bolts are the only bolts that hold the starter to the bell housing. on the v8 one of the long bolts also has a bracket to the oil pan. yes, if you allow it to, the starter can come apart when you unbolt the long bolts. the idea is to keep it together until you can put a couple of nuts on the long bolts after you have it out.
1949 F-1 Flatrod II (flat paint, flat motor)
Keeping one more flathead alive
It smoked, but gave it up 7/26/2013
East Glenville NY
r_reed is offline   Reply With Quote
Old 05-17-2015, 10:17 PM   #11
Bob C
I went and looked at the starter on my 49 6cyl pu and
you need to remove the bolts that go through the starter,
just don't pull then all the way out.
Bob
Old 05-17-2015, 10:23 PM   #12
Harper
Harper's Avatar
I can't get it to load
I will post it under my photos when I can my internet to cooperate
Old 05-17-2015, 10:24 PM   #13
Tinker
Tinker's Avatar
More stuff for you.
http://www.fordsix.com/forum/viewtopic.php?f=18&t=66591
Old 05-17-2015, 10:26 PM   #14
Harper
Harper's Avatar
\uc0\u8236 }
Old 05-17-2015, 10:32 PM   #15
JSeery
JSeery's Avatar
Can you get another shot more from the front toward the back that shows the mounting area?
Old 05-17-2015, 10:35 PM   #16
Tinker
Tinker's Avatar
Loosin the two bolts and tap the starter with a soft hammer. If it doesn't knock loose try a scrwedriver and a hammer at the starter face and bell. Little force will do it. Then unscrew the bolts out the bell and wiggle the starter out. Angle to engine and up some
It's the same starter as the flat v8. Bendix may be different. Same deal later with the yblock and inline 6, same starter/flywheels. Ford was frugal.
Old 05-17-2015, 10:43 PM   #17
Tinker
Tinker's Avatar
Starter will come a part as mentioned but they usually keep together. It won't just fall a part into a jigsaw puzzle. It's just really three parts. The face, the back, and the rotor. No big whoop
Old 05-17-2015, 10:53 PM   #18
Harper
Harper's Avatar
Thanks guys
I will try to remove it tomorrow. I have a dr appointment with my knee then after that I will try again.
After thinking bout the lengths of the three bolts removed I now realize the two 9/16" bolts are only about a half inch long, so they are for the bell housing to engine plate more than likely, and the 5/8" x 2" bolt I'm not sure of.
Old 05-17-2015, 11:01 PM   #19
Tinker
Tinker's Avatar
As mention don't remove those long bolts completely. Just so they are no longer in the bell. hope the doc visit goes well. Let us know how it all turns out. Starter and the knee.
Old 05-17-2015, 11:16 PM   #20
JSeery
JSeery's Avatar
Now I do know about knees!!! Had one replaced 3 years ago.
